  #11
Old 04-15-2021, 08:53 PM
SMRacer's Avatar
SMRacer SMRacer is offline
Default RV8 weight and balance
O-360 parallel valve
Whirlwind RV200 prop
EarthX battery on firewall
Smoke system in forward deep well
1121: Empty weight
CG: 79.17
Jim
Leesburg, VA (KJYO)
RV4 N444JT (sold)
RV8 N37PK
Old 04-16-2021, 12:16 PM
bifft bifft is offline
O-360 with Rotec TBI.
Inverted oil
Catto-three blade
Lithium battery on firewall
no lights or gyros.
1016 lbs CG 79.85
Old 04-16-2021, 02:08 PM
YvesCH YvesCH is offline
IO-360 (superior cold sump / double pmag)
Inverted oil and engine preheater
Earth X 900 on firewall
Grove gear
Catto 3 Blade
Rear Panel (Garmin G3X 7“)
Leather Interior and Carpets
Fully painted (3 colors and clearcoat)
Empty: 1029lbs / CG: 79.84
Yves - Basel, Switzerland
RV-8 #83458 HB-YUA
Donation 2020 done
Old 04-16-2021, 08:17 PM
Chris Engler Chris Engler is offline
IO-360 (superior cold sump/dual pmag)
Engine preheater
Earth X 900 Behind Baggage Compartment
Full Leather Interior with Heated Seats
Full Carpet
Dual 10.4 inch GRT Screens
WW 74 HRT Prop
Empty: 1147 lbs / CG: 76.7
Chris Engler, Greene, NY
RV 8 Completed and Flying (N184CE), Showplanes Fastback and Cowl, Barrett IO-360; Dual GRT 10.4 HXr
Kitfox 7; Rotax 914, Built and Sold
VAF donation gladly paid through April 2022
Old 04-27-2021, 04:22 PM
usafmd usafmd is offline
Trying to configure W & B for RV-8 in Foreflight. Getting notices saying "No forward CG limit is defined at the maximum takeoff weight". Same for aft CG limit. Can anybody explain to me how to set this up? I don't see where to do it. Thx.
Old 04-27-2021, 05:08 PM
RV8JD RV8JD is offline
Here is a screenshot of my FF W&B Setup tab for my RV-8 (for the Utility Category limits) that may help. Note the inputs at the bottom left in the red box. I had to set up a separate W&B for the Aerobatic Limits.
Here is a screenshot of my Excel spreadsheet W&B that has all of the limits and Arms for plotting purposes that may also be of help.
My RV-8 has the Dash-One wing, hence the Max Aerobatic Gross Weight of 1600 pounds. RV-8s without the Dash-One wing have a Max Aerobatic Gross Weight of 1550 pounds.
Hope that helps.
Carl N.
RV-8
KAWO
