  #11
Old 08-08-2020, 01:58 PM
az_gila's Avatar
az_gila az_gila is offline
Talking
Originally Posted by Pat Hatch View Post
Chris, the Spruce part number is 07-17968, $80.75.
Or in local currency... https://www.lasaero.com/parts/?search_part=07-17968
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-08-2020, 02:03 PM
chris mitchell chris mitchell is offline
Thank you Pat!
Chris
Chris Mitchell
Repeat offender;
RV-8, QB, built, flown 150 hours, sold;
RV-4 - attempted repair, rebuild and remediation - abandoned and junked ;
RV-4 fuselage and wing kits - both at QB stage;
2015-2018 dues paid!
Old 08-08-2020, 10:18 PM
airtractor8 airtractor8 is offline
This RV builder has some very detailed info and pics on the inner workings of both Plane Power and B&C alternators. https://www.myrv10.com/N104CD/mainte...cts/index.html
Old 08-09-2020, 06:38 AM
DanH's Avatar
DanH DanH is offline
"We uniquely modify each alternator..."
Sheesh. Talk about seeing how the sausage is made. Were the previous generation B&C alternators also internally hacked like that?
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-09-2020, 06:58 AM
74-07 74-07 is offline
Yes and I believe that Bob Nuckolls wrote about this modification. If I remember correctly, that modification creates the overvoltage protection that is internal in the Plane Power alternator. It's the reason I asked if the ACS regulator has the modification. Hope it does as I've got a bad one on my shelf that I'd love to get fixed and Plane Power said parts were not available.
Old 08-09-2020, 07:23 AM
Can someone please confirm that the regulator from ACS DOES have the Plane Power modification? Perhaps, since some carry the ACS part as a spare, a photo of the part? Just seems very strange to me that PP would tell me that the parts nor any overhaul was available and that a very well known (locally) overhaul facility also told me the parts were not available after searching for a couple of weeks.
Old 08-09-2020, 10:06 AM
tsneidin tsneidin is offline
Default What voltage should I seeing on my efis
I have the plane power 60amp internally regulated alternator from around 2009. I highest volatage I see is 13.2 on the efis with master on/avionics. I see 14.2 if I switch on the E-buss. Is this normal?
Todd Neidinger
RV-9 Flying
Old 08-09-2020, 11:09 AM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
Todd,
Yes, it's normal. Your efis is likely fed through the ebus diode, which creates a voltage drop. Once you turn on your ebus switch it sees bus voltage.
You can improve the voltage drop by using a Schottky diode on the ebus.
Lenny
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 650 hrs
OnSpeed development team
Old 08-09-2020, 11:14 AM
The regulator sold by Spruce is the same thing as the original. It's also a Hartzell part number. I replaced mine with one from Spruce. Looks exactly the same with the wire included. They give you the whole assembly with brushes and everything.
Lenny
Lenny Iszak
Palm City, FL
Old 08-09-2020, 11:20 AM
Thank you.
