Old 04-07-2021, 02:31 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Default GMA 345 vs. GMA 245
Originally Posted by supik View Post
I have the GMA 345 wired to the G3X Touch PFD.
The serial bus communicates, it will show the Audio Data Bar on the display as long as the GMA245 Audio Panel is selected in the G3X config menu. It says AUDIO PANEL MISMATCH, obviously, but will display the indications.
As soon as I set the Audiopanel to the correct GMA 345, the Mismatch message disappears but the Audio panel indications are no more present on the PFD after reboot.
What am I doing wrong?
Igor,
The GMA 245 was purpose built for integration with G3X Touch displays, and communicates with the G3X Touch via CAN. The GMA 345 does not have the same level of integration as the GMA 245, it communicates with the G3X Touch via serial bus, as you mention. This datapath only facilitates limited integration with the G3X Touch. You will want to configure your displays to reflect that you have a GMA 345 connected to the system.
Justin
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 04-07-2021, 05:48 PM
supik supik is offline
Originally Posted by g3xpert View Post
Igor,
Justin
Justin,
this is what I already did. The serial bus is set to GARMIN INSTRUMENT DATA and the Audio Panel Type to GMA 345 in the G3X config menu. The panel will not show on the CNS bar. And yes, it is enabled to show on the PFD.
Igor
RV-10 in progress
Build Log
Old 04-13-2021, 04:07 AM
more pics:
https://i.ibb.co/kSDKfXr/IMG-0545.jpg
https://i.ibb.co/CMpT9gz/IMG-0547.jpg
https://i.ibb.co/hsSVHHc/IMG-0546.jpg
Igor
RV-10 in progress
Build Log
Old 04-13-2021, 08:42 AM
g3xpert's Avatar
Default GMA 345 Capabilities
With a GMA 345, you are not going to have the highly integrated control of the audio panel through the G3X Touch display as you would with a GMA 245. Please see page 35-143 of the G3X Touch Installation Manual for more information.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 04-13-2021, 09:38 AM
Justin
Justin,
This I do understand, all I want is the G3X touch to display the selected Com and Mic plus the marker beacons as described in the manual.
Igor
RV-10 in progress
Build Log
Old 04-13-2021, 09:42 AM
g3xpert's Avatar
Default Pictures
Justin,
Igor,
Can you send your pictures to G3Xpert@Garmin.com? The links appear to have a problem, we are unable to open them.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 04-13-2021, 09:51 AM
Dad's RV-10 Dad's RV-10 is online now
Igor,
Justin
Igor's pics:
Click image for larger version
Old 04-16-2021, 12:25 AM
Thanks Dad's RV-10
Justin, Iím already in touch with your G3Xpert team via email..
Igor
RV-10 in progress
Build Log
