Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 04-12-2021, 12:22 PM
comatb comatb is offline
Default tailBeaconx Wingtip Mounting PAPR?
Has anyone mounted a tailBeaconX in a wing tip and done a PAPR to see if it's performance is degraded by the proximity to the wing? We are looking at mounting one in a RV6 wing tip as the tail mounting is quite susceptible to damage on the taildragger.
Old 04-13-2021, 09:59 PM
RV-4 RV-4 is offline
Thumbs up tailBeaconx Wingtip Mounting
Hi Bill
I got your e-mail and for the benefit of everyone here planning on doing the same, I'm in the process of doing just that and will report back here once everything is completed.
I should be doing the wiring tomorrow so it should be soon.
Cheers
Bruno
Old 04-14-2021, 06:46 AM
Default tailBeaconX Wingtip Mounting
Hi Bruno,
Thank you that sounds great. Good luck.
Old 04-14-2021, 10:38 AM
azrv6's Avatar
azrv6 azrv6 is offline
Bruno, hopefully you will be able to post a picture or two of how you mounted it in the wingtip.
Dave Binkley
RV-6, O-360-A1A, C/S
1932 Monocoupe 110, Warner 145 (http://gobinkley.com)
Sedona, AZ
Old 04-15-2021, 12:08 PM
Thumbs up Tailbeacon-X installation
Hi Dave
''Bruno, hopefully you will be able to post a picture or two of how you mounted it in the wingtip.''
Hopefully I'll be able to, if not I'm sure someone here on VAF who's more ''Computer Oriented', than me will do it for us.
I had to take the day OFF today because it is simply too cold over here to work on the a/c.
Bruno
Old 04-24-2021, 04:03 PM
Mtherr Mtherr is offline
Any update? Looking forward to some real life experience with this..
Michel Therrien
RV6A "Second Wind" C-GERZ (born N242UL)
Old 04-24-2021, 05:04 PM
Originally Posted by RV-4 View Post
Hi Bill
Cheers
Bruno
I'm sure Bruno will update everyone when he can.
Old 04-26-2021, 10:30 PM
Hello everyone
Just a quick update on my Tailbeacon-X installation in the wingtip of my RV-4..
I completed the install last week end and did a first power up and I'm glad to report that the smoke stayed in the wires..;-)
The initial set up via the APP went well but you have to be fairly close to the Beacon to log on the Beacon WI-FI to do the set up..It is well explain in the info from UaVionix.
The beacon is communicating well with the AV-20E and if I change the code in the transponder, it shows right away in the APP.
The transponder is also responding when interogated by ATC Radar even on the ground.So looking good so far.
I've got a couple things I need to check with uAvionx regarding the pressure altitude been displayed and traffic ..
I will report back once I have a chance to fly the a/c ..
Stnd by for more..
Bruno
p.s; Trying to upload a picture but I'm not sure if it works. ( Well obviously it didn't )
Old 04-27-2021, 03:58 AM
PCHunt PCHunt is offline
I'm curious why folks are installing a Tailbeacon on a wing, when uAvionix sells a wing-tip version of the same thing??
There's gotta be a reason.........................
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2021 Donation+, Gladly Sent
Old 04-27-2021, 04:20 AM
Bruno, great to read this status. Looking forward for more info after you can experience it. Does the configuration software allow to keep the light turned off?
Pete, uAvionix does not sell a wing tip transponder that satisfies the requirements for Canada yet. The SkyBeacon is a 978 repeater only. This (wingtip 1090 ES with dual antenna) should come in June accorfding to a response I have from them. Even then, this will not meet my requirements as I need a light with the rear position light as well on the wing tip. Moreover, I prefer the look of the Orion 600 freshly installed than that of the X antenna.
Michel Therrien
