Old 01-18-2021, 08:50 AM
asw20c asw20c is offline
Default Another Gotcha
I just confirmed with Vans another error in the plans. On page 31-05 figure 1 shows the AN833-6D (the elbow fuel fitting that penetrates the firewall) clocked up 25 degrees from horizontal. On page 31-11 figures 2 and 3 have very different clocking angles for this same fitting depending on whether you are building the taildragger or tri-gear. The clocking angle found on page 31-05 IS NOT CORRECT. Use the clocking angle appropriate for your build found on page 31-11 instead.
I'll be adding this to the Gotcha sticky.
Empennage Complete
Wings Complete
Fuselage Underway
Old 01-18-2021, 11:37 AM
Sam Buchanan's Avatar
been here awhile
Wow.....the plans are so detailed they tell you how to clock fittings??
Whatever happened to building an airplane?
Sam Buchanan
RV-6
Fokker D.VII replica
Old 01-18-2021, 11:44 AM
bjdecker's Avatar
bjdecker bjdecker is offline
I think they went a little overboard here...
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 01-18-2021, 11:46 AM
rv8ch's Avatar
rv8ch rv8ch is offline
I agree!
A late friend of mine that built two RV-4s was pretty stunned at my 2003 vintage RV-8 kit - I can't imagine his reaction to the RV-14. One tip I've given a lot of builders is to look at the RV-14 plans - they can help even on non-RV-14 models. They are really good.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-18-2021, 12:07 PM
rvbuilder2002's Avatar
Depends on your perspective I guess......
If you keep in mind that the RV-14(A) is a very complete kit with every design aspect done for the builder in advance (assuming they don't choose to go off trail and make any changes). So the firewall fwd kit will come with parts (in this case a fuel hose) that will only fit if all of its associated parts are installed correctly (and it helps pump up the egos of all the earlier builders that had to work through this type of detail on their own )
Scott McDaniels
Hubbard, Oregon
Old 01-18-2021, 12:59 PM
rv8ch's Avatar
... (and it helps pump up the egos of all the earlier builders that had to work through this type of detail on their own )
Worked for me! I think I'll update my signature "I clocked my own hoses - all by myself!"
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-18-2021, 02:56 PM
Uh huh. For those with any more smart *** comments, it is impossible to know which way this fitting should be pointed unless you are familiar with the firewall forward kit already. Most of us aren't. And since you install it with gorilla snot to seal around the fitting, it takes more than simply disconnecting the fuel line and loosening the nut.
I'm hoping I am saving someone some headache down the road by pointing the error out in the plans. Good on ya for trivializing an attempt to help out fellow builders.
Empennage Complete
Wings Complete
Fuselage Underway
Old 01-18-2021, 05:17 PM
Jetmart Jetmart is offline
Thank you, I certainly appreciate all and any heads up on issues like this.
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Started October 22, 2019
Engine, prop, and cowling to complete
2021 Dues Paid
Old 01-19-2021, 12:29 AM
rv8ch's Avatar
I figured there was more to it but could not resist a little friendly ribbing of you RV-14 guys.
Mickey Coggins
http://rv8.ch
"Hello, world!"
