Old 09-24-2021, 10:09 AM
Glen P Glen P is offline
Default RH Canopy Latch with “Almost a -14” mod
Hi
I’ve installed the “Almost a -14” mod on my RV7 with tip-up canopy. I’m wondering what people do on the RH canopy latch. I’m considering doing something similar to the LH assembly but not have it penetrate the fuse - just provide the fore and aft force to latch/unlatch. That does seem overly complex for what I need. I’d appreciate your thoughts.
Click image for larger version
Glen Palmer
Toronto, Ontario
Working on -7 avionics/wiring
Dues paid July 2021
Old 09-24-2021, 11:41 AM
ty1295 ty1295 is offline
I did a push/pull cable from pilot to co-pilot side. Took some tweaking but overall works well.
Jeff Scott
RV9A First Flight 9/30/19
Old 09-24-2021, 01:31 PM
A fairly long one? Through the baggage compartment bulkhead?
Glen Palmer
Toronto, Ontario
Dues paid July 2021
Old 09-24-2021, 02:34 PM
Yes, goes back behind the baggage bulkhead panel around and forward to co-pilot side. Made some brackets for each side of the cable. A day at the hangar and it was working. That was 2 years ago.
Jeff Scott
Old 09-24-2021, 06:02 PM
abwaldal@gmail.com abwaldal@gmail.com is offline
The cable is 8' 3" long and Tankerpilot75 put pictures on this site look it up if you can find it.
I'll attach picture of what I did in the cabin. Makes a real good installation.
I took the time to look and didn't find it. I also do not seem to be able to find the supplier of the cables I got for both my RV-6A and RV-6
Art
ID:	16258  Click image for larger version
ID:	16259  Click image for larger version
ID:	16260  Click image for larger version
Last edited by abwaldal@gmail.com : 09-24-2021 at 06:27 PM. Reason: people needed more info
Old 09-24-2021, 06:59 PM
PBell PBell is offline
I did it the way he did on his RV6. Ordered the clevises and an additional torque tube from Vans. Oh and extra bushings. Mine works smooth 👍
ID:	16262  Click image for larger version
ID:	16263  Click image for larger version
PBell - 92293
N393RV reserved
2021 donation made
http://myrv-9abuild.com
Old 09-25-2021, 04:44 PM
Default Extra info
If you ever want to get into the back of your plane to do any work. You will love having the cable solution.
Remove the flap motor mount, RV-14 seat mod, and seats of course, and you have much easier access into the fuselage.
I just did a panel upgrade and added an autopilot. Installing the pitch servo was a no brainer. And wiring back there was a lot easier too.
Oh ya another benny is the easy adjustment of the latch hooks. My canopy is never coming open in flight again that is assured.
Art
Old 09-25-2021, 09:06 PM
6ato14a 6ato14a is offline
Default Rh latch
Originally Posted by Glen P View Post
Hi
I will be sending you a pm.
Old 09-26-2021, 03:01 PM
For those of you that have used cables, is there any concern that a broken cable with the canopy latched closed (in the hangar or parked on the ramp) would make the canopy impossible to open?
Glen Palmer
Toronto, Ontario
Dues paid July 2021
Old 09-26-2021, 06:36 PM
Default Cable breakage
Well I for one can tell you that a cable breaking is the last thing I will worry about. These are not some little Bowden cables. I be you could lift a car with the ones I got.
No I can't find out where I bought them. But Tankerpilot75 had a posting that I got the supplier and part number from.
I just measured the one I have hanging on my wall that goes in my unfinished RV-6.
The plane is gonna break before you break the cable.
OH your mileage may vary Art
