VAF on Twitter:
@VansAirForceNet
View Poll Results: What flap setting do you most frequently use at touchdown?
No Flaps 2 2.02%
10 to 15 degrees 11 11.11%
Full Flaps 86 86.87%
Voters: 99. You may not vote on this poll
Old 09-25-2022, 07:08 PM
KJBSouth's Avatar
KJBSouth KJBSouth is offline
Default POLL: Landing Flap Setting
What flap setting do you routinely use on short final and touchdown?
Old 09-25-2022, 08:29 PM
RV6_flyer's Avatar
With manual flaps in my RV-6, I typically use the 3/4 setting, notch 3, full flaps, notch 4, is difficult to get above 70 KIAS in my airplane. 3/4 or 30-degree setting is not an option in your poll.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-25-2022, 09:04 PM
Mel's Avatar
Mel Mel is online now
Default Insufficient Options.....
Put in 13° on downwind and add whatever is necessary from there.
Usually full flaps on final for my 1500' strip and dump them upon touchdown.
Manual flaps here too! 0°-13°-26°-39°
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
Recipient of EAA Tony Bingelis Award and Wright Brothers Master Pilot Award
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-25-2022, 10:11 PM
FlyinTiger FlyinTiger is offline
Arrow It depends
Technique:
Full flaps in steady lighter winds
1/2 flaps in gusty or crosswinds greater than 10 knots, less than 20 knots
0 flaps in gusty or crosswinds greater than 20 knots
AL
Launching from SC45
Old 09-26-2022, 11:44 AM
andoman andoman is offline
A single flap deployment for me.
I put out full flaps abeam the numbers allowing me one and done trimming for flap deployment.
Last item on my landing checklist is flaps thus minimizing distractions from abeam to touchdown.
I keep it tight and fly one approach speed (on AOA gauge) til over the fence.
But I’m a Navy guy.
-Short gear -4, electric flaps.
-Always full flaps for gusty crosswinds. The flat attitude of the short gear makes half flaps and no flaps sketchy in that she’s still flying for a long time even after all three wheels are on deck.
"The plane won't build itself..." RV-7A N7.62MM sold
-RV4 purchased. Extensive refurbishment complete. “Takes off by it’s self, flys hands off, lands by it’s self...”
-HRII project: paint and panel to go!
Old 09-26-2022, 01:35 PM
jcarne's Avatar
jcarne jcarne is offline
Yep, not enough options. I have settings for 15-30 and full. I almost always use 30 unless I am training short field.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Old 09-28-2022, 03:22 PM
abuura abuura is offline
10 degrees, period.
David Abrahamson
Reston, VA
ATP, CFI, Repairman x 2
RV7, N98DA, TMX-O360, CS, slider
2022 dues paid!
Old 09-28-2022, 03:37 PM
gasman gasman is offline
Always full flaps (manual). My hangar is off the first offramp at 700'.
Every landing is short field at my home base. Except when I need fuel.
VAF #897 Warren Moretti
2022 =VAF= Dues PAID
Old 09-28-2022, 04:40 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
My 7A was OK for IFR so I worked out that I could fly the glide slope at 100 KIAS down to 200' AG, cut the power, raise the nose and then deploy flaps when airspeed low enough. Did not need brakes on any runway long enough for an ILS. 100 was much nicer for flying the glide slope well and made go-arounds a lot nicer and safer, too. Delaying use of flaps until the runway was assured meant a much better go-around if that was needed.
For VFR landings, one notch was plenty. More did not allow slower speeds but did change pitch and airspeed. The airplane could not fly slower with more flaps but would slow down more quickly.
The prop was a Catto FP, btw. That made it harder to slow down than with a CS prop. So for a short field, more flaps would be potentially useful.
H. Evan's RV-7A N17HH sold at 268+ hours
Bought N512RV (RV-12)
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" 2021.
my website
