Fill and smooth?
WingnutWick
I’m finishing up fiberglassing the intake ramps onto my cowling and I’m wondering what to use to smooth and blend with. Does your normal bondo work or is there something more appropriate for this application?
Thank you!
Polyester filler will work fine, micro/epoxy even better. Can't ever matter much inside the top cowl.
West Systems 410 fairing material mixed as dry as necessary to prevent running. Sands very well.
