w/a Donation
VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Model Specific > RV-14
Old 10-09-2017, 12:24 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Default Page 38-14, Section 4 ... gap?
Hey guys, on page 38-14, section 4, joining C-01405-R+L, did you have a small (3/32'ish) gap between these two pieces once everything was together before match drilling the Canopy Handle Assembly?
Tech Counselor
N196 RV-14A #140376 (Sold) 2019 Bronze Lindy
N169 Carbon Cub EX-3 (Finishing)
N15Z RV-15 (Waiting ... impatiently)
Old 10-09-2017, 12:46 PM
MED's Avatar
MED MED is offline
Not sure it is correct, but it is what I got.
Click image for larger version
MED
140236
N435MD
Miss March 2020
Old 10-09-2017, 02:51 PM
Don E Don E is offline
Default Mine does
The C-01442C Canopy Fixture when cleco'ed on created a gap very much like yours. I went with it; and it seems to work now that I am fitting the canopy.
Old 10-10-2017, 11:37 AM
bkervaski's Avatar
Completely duplicate set of parts, exact same result, moving on ... (thanks for the responses)
Tech Counselor
Old 09-14-2023, 04:49 PM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
[ATTACH]Click image for larger version
Name:	Canopy bow issue.pdf
ID:	47965[/ATTACH]A little detective work on this RV14 canopy issue.
Folks with completed canopies. Is there a negative gap (Back window proud) on the top middle of your canopy between the back window and the canopy?
See PDF below.
Pete
RV14A Tail kit 95%
Wing kit 95%
Fuselage QB in progress... finally delivered 18months late
RV 14 WIKI in Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 18,19,20,21 Military exempt
Old 09-16-2023, 08:58 AM
mc607's Avatar
mc607 mc607 is offline
Pete,
It is very common for these parts to align as you show in your pictures. Some builders have had them replaced and others, like myself, have had to buy new parts. I got lucky and my second set aligned much better. I am on page 38-21 and just starting to see the alignment with the roll bar and it’s not bad. There’s a lot going on at that interface so the likely hood of the window/canopy lining up perfectly are quite low. I plan to use non metallic washers under the window or canopy to get it aligned where I like it. Side note, use the C-01405D under this joint and not its little brother C-01404A.
This was the original, replacement was much better.
Todd B
Old 09-16-2023, 12:17 PM
HAL Pilot's Avatar
Thanks for the pictures
To clarify my question, I am trying to figure out if the gap shown on the bottom of the canopy bow should be consistent all the way around. I assume so.
Pete
RV14A Tail kit 95%
Wing kit 95%
EAA 1300
Old 09-16-2023, 01:21 PM
mc607's Avatar
Hopefully this helps. My window is done and I did notice that the window contacts the aft edge of the shim and not the fwd edge all the way around. Will deal with that on final install with a bead of silicone and nonmetallic washers before snugging up the screws.
Pins are engaged so this is what I ended up with.
Todd B
Old 09-16-2023, 06:05 PM
HAL Pilot's Avatar
Thanks for the pictures. That does seem to confirm that the 3/32 space should go all the way around. I reframed my question with Vans. Hopefully I get an expanded answer.
I have been laying the frame out and it looks like the gap is 5/64 on one side and 7/64 on the other side so going to try to come up with a compromise in the middle.
Pete
RV14A Tail kit 95%
Wing kit 95%
EAA 1300
Old 09-17-2023, 05:58 PM
HAL Pilot's Avatar
To minimize storage space used on this forum I updated my original PDF on this thread with my findings and how to fix the issues.
Pete
RV14A Tail kit 95%
Wing kit 95%
EAA 1300
