Well, it's a brutal experience. Route your wiring and tubing to allow the best access possible. Also, schedule a chiropractor visit after each gear bolt torque session. Someone has probably come up with a better hardware solution that is easier to deal with but mine are bolted up per plans...at least as they were drawn up back in the late 90's. I had to kludge up a socket and a short piece of box wrench handle into a uniquely angled affair to access the outboard nuts. I also had clearance issues with the nuts that affix the screws coming in from the side skins right at the gear bolt nuts. I removed them entirely and installed some mega pop rivets found at a local military surplus store. That was the only way I could get a wrench on those $@#%* nuts.
Once tightened up after the first fifty hours, they haven't loosened up again since. Make sure you really debur and clean out any chips in this gear attach area so you don't lose any initial torque from scrunching down on bits of metal.
Have fun.
