Old 11-14-2005, 10:25 AM
13brv3's Avatar
13brv3 13brv3 is offline
Default plenum kit?
Greetings,
I've noticed that some folks are using plenums on their engines now, rather than the traditional baffles that seal to the top canopy. Does anyone make a pre-made plenum for the RV-8, with a stock cowl? I know Sam James makes one, but I think it's only for their cowl.
Rusty (emp kit just arrived, QB coming in Jan)
Old 11-14-2005, 11:07 AM
N62XS N62XS is offline
Default Plenum Options
Jon Johannsen makes one, but most of the web sites I've seen use Vans baffling and put a top on it. ?he guys at Showplanes.com are said to be close to a better version of the James Holy Cowl, but I've yet to see it.
On my next 8, I plan to mold my plenum out of foam and lay it up with glass and vinyl ester resin.
Robby
Old 11-14-2005, 01:33 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Make your own
The JJ unit is too much money ($800?). You can make your own from aluminum off of Vans basic baffle kit. You can also use Vans baffle kit and make a fiberglass cover. Robby suggest vinyl ester resin. I am not a Fiberglass guy but (I THINK?) the Vinyl ester stuff shrinks and is not good with heat. I think epoxy resin is better? Check it out first. Look at builder sites for ideas. G
http://home.mindspring.com/~rv6/RV6site/index.htm
http://rv8a.tripod.com/engine.html
The following is for Rockets, but you get an idea
http://www.vincesrocket.com/Engine%20and%20Prop.htm
Old 11-14-2005, 03:06 PM
Default Vinyl Ester
G:
The reason I mentioned Vinyl Ester is because James' plenum is manufactured using that material. To me it is all nasty stuff.
Robby
Old 11-14-2005, 05:40 PM
13brv3's Avatar
Thanks for the info, particularly the links to custom plenums. I've seen at least one of those in searches through the archives, but it's clear there's most than one way to do this. Unfortunately, my hope was that someone would have a reasonably priced plenum available, or at least plans to modify the Van's baffle kit.
On my first RV-8, I spent almost a whole vacation week working on nothing but baffles. I just couldn't believe how long it took, but they came out fine, and worked fine. I do think there are advantages to putting a lid on the baffles, rather than trying to seal it to the cowl, but I'm not sure "time to build" is going to be one of those advantages unless someone sells one ready made
I'll take a look when I get to that point, and decide if it seems easier to make them stock, or put a lid on it.
Rusty
Old 11-14-2005, 07:00 PM
Kevin Horton's Avatar
Kevin Horton Kevin Horton is offline
Thanks for the links. Has anyone come up with a decent way to seal the cowl inlets to the plenum, assuming you are using the standard Van's inlet shape? I'd love to see some pictures of that. That's the one thing that still baffles me about making a plenum.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 11-14-2005, 11:57 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
If you just need a decent (not perfect way) do what I did- use airseal fabric riveted to the top cowl to seal the top of the plenum, in the same way that the bottom cowl is sealed to the standard baffles. It's not as tight as, say, a Sam James, but it works, as you say, decently.
http://home.mindspring.com/~rv6/RV6site/plenum.htm
Jeff Point
RV-6, RLU-1 built & flying
CFI, Tech Counselor, Flight Advisor & President- EAA Chapter 18
Milwaukee
Old 11-15-2005, 03:31 AM
pmercier's Avatar
pmercier pmercier is offline
Default Custom Plenum
I plan on fabricating my own plenum using epoxy resin. I'm also going to use the inlet rings from Sam James to reduce the cooling drag. The plenum will be screwed to the standard vans baffle kit.
Philip Mercier, RV-4
Abbostford BC.
http://members.toast.net/pmercier/project2/index.html
Old 11-15-2005, 06:15 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Here's how I did mine on my Rocket.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 11-30-2011, 01:24 AM
Janekom's Avatar
Janekom Janekom is offline
Default Have you seen this?
Have you seen this?
http://rvbits.mybigcommerce.com/prod...er-Plenum.html
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2021 WITH A SMILE
