Old 09-07-2020, 07:12 PM
airtoby's Avatar
airtoby airtoby is offline
Default Garmin 530 nav data
When going from Jeppesen Nav, terrain, & other databases to Garmin data on a 530 And a G500 Is there any concern or should it be a straight forward update. I bought the new USB adapter from Garmin. I just donít want to cause a Problem that will require a repair at Garmin Etc
Airtoby
RV-6 O-360 CS 750 hrs and counting
RV-4 O-360 CS Bulit and sold
airtoby@tds.net
Old 09-08-2020, 04:01 AM
catmandu's Avatar
catmandu catmandu is offline
I switched the RV from Jepp to Garmin data and had no issues at all. I helped a friend do the reverse last month, also no issues. The boxes don't seem to care where the data comes from.
Mike C.
Sierra Nevada
RV-6A bought flying
Old 09-08-2020, 08:10 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default GNS Database Card
Airtoby
As mentioned above, there will be no changes other than the data card programmer you use to transfer the databases from your computer to the data card. There are no configuration side settings on the GNS that need to be adjusted.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 09-08-2020, 02:25 PM
airtoby's Avatar
Thanks for all of your reply's.
What a great forum
Toby
airtoby@tds.net
