Keep VAF
Going
05-04-2019, 08:39 PM
Fitting that snaps on/clamps on brake bleeder nipple?
Hi VAF,
Does anyone know of a fitting that will snap on/clamp on to the brake bleeder nipple fitting?
I've been using a length of hose but it pops off all the time and makes a mess. Brakes are Matco.
Thanks!
05-04-2019, 08:50 PM
Senior Curmudgeon
My old ATS bleeder came with such an animal.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
05-04-2019, 09:12 PM
I secured mine with safety wire.
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
05-04-2019, 09:31 PM
VAF Moderator / Line Boy
Check Aircraft Spruce for this:
https://www.aircraftspruce.com/catal...lickkey=980347
I think that’s what you’re looking for. Cleveland Brake Bleeder Adapter.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
05-04-2019, 11:37 PM
Senior Curmudgeon
Mike Starkey
VAF 909
Rv-10, N210LM.
05-04-2019, 11:39 PM
That looks great! Thanks for all the quick replies.
05-05-2019, 12:01 AM
Try a smaller hose. I just pressure bled mine last night with regular 1/8 clear hose. Didn't have any issues.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
05-05-2019, 07:57 AM
Any grease gun will have that fitting. I simply unscrewed it from one of my older grease guns, took it apart and cleaned out the grease.
Just looked online. Grainger has the fitting for $2. Many others between that and $5.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
05-05-2019, 01:22 PM
1/4" nylon
I used a piece of quarter-inch OD static/pitot tubing. It slipped inside the tubing called out in the DIY garden sprayer bleeder plans (safety wire to secure), and the ID was perfect for a slip fit over the bleeder zerk.
I'll grab some photos this evening if I remember.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - Phase 1 flying
donating monthly to the VAF - thanks, Doug
05-05-2019, 05:21 PM
The advantage of the grease gun fitting is it is a check valve so you won?t spill any fluids.
However, as little as you need it, cleaning up a few drips of fluid now and again isn?t that big of a deal.
Use whatever works.
Bucker Jungmann
RV1 - Proud Pilot.
Thread Tools |
Display Modes |
