Old 11-28-2015, 04:56 PM
petersb petersb is offline
Default Jeppesen Data for GRT HXr
Has any Canadian installed the Jeppesen Data into their GRT HXr or Dynon .
What do you get, Airport frequencies, procedures, locations on the Map Screen ?
Is it the same as the Canadian Flight Supplement ?
Does it updated airspace, ie: Class "C" etc ?
Peter
RV7A New Dec 2013 - 360, C/S, slider
RV6 - 1600 Hours ---- Sold
Old 11-28-2015, 10:42 PM
vluvelin vluvelin is offline
Default Jeppesen db
I purchased my 7 with GRT HX & FAA databace loaded and when was flying from Toronto to montreal
Noticed wrong airspace when on final almost in all airports was not alighned with centrline in some cases 30 degrees off
Jeppesen db corrected the problem
RV7 C-GLLT - FLYING
RV7 C-GZZY- NOTFLYING
2017 June RV7 Emp in works!
VAF SUPPORTER
2014, 2015, 2016, 2017, 2018
Old 11-29-2015, 06:24 AM
Thanks for the update
Peter
Old 08-12-2018, 01:53 PM
Funguy's Avatar
Funguy Funguy is online now
Default GRT Jeppesen Obstacles database
So I went ahead and purchased the Navdata for my brand new GRT Sport Ex. Does anyone have an opinion on purchasing the Obstacles Database? Is the GRT provided database accurate for Canada as well as the USA? Thanks in advance!
Cheers, Sean
RV6, Flying C-GOFG
CLA4 - Holland Landing
Toronto ON
Donated to Nov 2021
Old 08-12-2018, 02:26 PM
if you are flying VFR get it ones from Jepp I wouldn't trust one from FAA due to mu experience with Nav data
I fly to CLA4 often never see RV there
Julian
RV7 C-GLLT - FLYING
VAF SUPPORTER
Old 08-12-2018, 10:08 PM
Funguy's Avatar
Default CLA4 - RV
Hi Julian, RV-6 is in the hanger. Send me a PM next time and I'll give you the tour.
Cheers, Sean
RV6, Flying C-GOFG
Toronto ON
Donated to Nov 2021
Old 08-13-2018, 08:17 AM
I parked couple of times in Hangar
maybe you were away
Will let you know next time I am going there
Tnx
RV7 C-GLLT - FLYING
VAF SUPPORTER
