  #11
Old 03-21-2018, 04:25 PM
DanH's Avatar
DanH DanH is offline
BTW, Scott is this month's centerfold in Kitplanes. You'll find an account of his adventures to date, and future plans.
As a bonus, Continental was kind enough to grant access to their development facility for an internal tour of the CD230/CD265 series diesel, with photos of the interesting bits. If you like the article, tell 'em next time you visit a Continental display.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-21-2018, 05:06 PM
Back to the rudder stop...
<Edited> I shouldn't have commented. I remembered the -10's rudder stop as being like the one on my -6. It isn't.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-21-2018, 05:59 PM
Flandy10 Flandy10 is offline
Mike,
I did use another bulkhead for the doubler and door. Was able to piggyback my order with another local builder. I had to run an aluminum angle along the right side of the doubler to stiffen that side. Feels like the original bulkhead. I'll try to get a picture for you.
Scott Flandermeyer
Rv-10 TDI 330 hrs
Fayettevile, GA
2021 VAF Donation complete
Old 03-21-2018, 06:05 PM
Default Rudder stop
Its a solid piece that rests against the VS spar.
Scott Flandermeyer
Rv-10 TDI 330 hrs
Fayettevile, GA
Old 03-21-2018, 06:59 PM
Wyzepilot Wyzepilot is offline
Originally Posted by Flandy10 View Post
Mike,
Scott,
I?m also interested in how you framed the access door in the bulkhead. Not sure if you were going to PM the picture to Mike but is there any chance you can post that picture here or PM it to me as well. Thanks!!
Dave
Old 03-21-2018, 10:56 PM
Plummit's Avatar
Plummit Plummit is offline
Originally Posted by Wyzepilot View Post
Scott,
Dave
Plus 1 (and a few words)
-Marc
RV-10
N814RV
2021 Donation Made
Old 03-22-2018, 06:45 AM
9GT's Avatar
9GT 9GT is offline
Default Baggage Bulkhead Door
What a fantastic idea building a door into the bulkhead. I stripped out those lower corner screws way to many times getting mine off and on!
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 03-22-2018, 07:09 AM
vic syracuse vic syracuse is offline
Super Moderator
All of Scott's airplane is an example of attention to detail and ease of use. Continental couldn't have asked for a better RV-10 test bed for the diesel engine.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 03-22-2018, 07:37 AM
DanH's Avatar
The stock stops shear the rivets (empty holes in the photo) attaching them to the hinge bracket? Got it. No fundamental change to the load path into the aircraft structure.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-22-2018, 02:19 PM
Default Bulkhead Access
Note: I am not an engineer nor has one reviewed this mod.
My opening inside the doubler is approx. 11" x 13". I did use a second lower bulkhead for the doubler and new door, but I guess you could do this without it if you cut the door opening carefully. Also, I had planned on using 1/4 turn fasteners, but the edge distances didn't quite work out, so I used #8 screws instead. The outboard side needed an aluminum angle for stiffness due to narrow strip of material remaining compared to inboard side. Run the angle to the bottom of the hinge and to the top of the aft bulkhead. Depending on how wide your door is you will need to trim the stiffener at the bottom to match the angle of the frame.
Send me a PM if you need more.
Scott Flandermeyer
Rv-10 TDI 330 hrs
Fayettevile, GA
