Old 01-23-2021, 06:38 PM
charosenz's Avatar
charosenz charosenz is offline
Airmaster props are popular with the Rotax folks.
A buddy has one on his 914 powered Rans, works well.
Electric control, so will work just fine with your Honda.
Pretty much same operation as a traditional C/S prop.
Thanks Mike,
If anyone has one (Airmaster prop/hub), or know of someone who does, PM me please.
Thanks.
Charlie Rosenzweig
RV6A - Honda (Turbo) engine. Now flying
https://vansairforce.com/community/s...158610&page=70
2021 Dues paid
Old 01-24-2021, 05:19 PM
Alchemist Alchemist is offline
It was great flying with you, hopefully many more flights to come . That Honda engine sure does sound good !
Justin Richardson
Vans RV-6A N457DH
Old 02-06-2021, 06:42 PM
charosenz's Avatar
Default flight performance
One thing I remembered about flying with Justin is that I asked him to slow down so we could match our speed when I was at 5000rpm. We were at about 3500msl. I honestly cannot remember our IAS, (maybe Justin can jump in here) but I think it was about 155-160mph. I asked what his RPM was and I think he said just under 2100rpm.
(I think my map at that moment was about 26-28". Needless to say the turbo was not really working much if at all.)
That is relatively slow for an RV6a top speed. Aside from the fact I have 6.00 tires and no wheel or leg fairings and a radiator slung underneath.......I remembered something much more significant. MY OWN prop speed. With the Viking PSUR I am only turning 2140 PROP RPM at 5000 engine RPM as well. That in mind, I am quite happy with the performance of this engine.
It is the nature of the fixed pitch prop and PSRU ratio that really hold me back, not the engine.
Unfortunately, Viking does not offer different ratios for their gearbox and I don't really know of any other PSRU with the vertical offset that I need to make this work well.
I also checked with Airmaster. I asked about using their CS hub with my warp drive blades. It "can" be done. But its $8k for just the hub and about $12K for their hub and prop blades. Not in my budget. But boy wouldn't THAT be fun!!!!
Charlie Rosenzweig
2021 Dues paid
Old 02-06-2021, 06:51 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
You might check out Ivo props. In flight adjustable, but as far as I know they are not constant speed.
I have a buddy with one on his Kitfox, setup with a toggle switch for climb or cruise. Works well for his needs.
I have no idea what HP range they work with, but I seem to remember seeing at least one case of an Ivo being on an RV.
https://ivoprop.com/
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-06-2021, 06:55 PM
airguy's Avatar
airguy airguy is offline
MT makes some nice electric in-flight adjustable props. Of course, also nice is the stack of $100 bills you'll trade for it.
Garden City, TX VAF 2021 dues paid
N16GN flying 750 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440
Old 02-06-2021, 07:24 PM
charosenz's Avatar
Mike,
Yes, I came really close to going with IVO. I know Ross has has excellent results with his. I talked with both IVO and Warp quite a bit back 4 or 5 years ago when I had to decide which way to jump. I went with Warp because they were the most supportive with my "unique" project. And they have been super supportive all along the way.
Greg,
Yes MT props are real nice.....but also outside my budget too.
Charlie Rosenzweig
2021 Dues paid
Old 02-17-2021, 08:52 AM
charosenz's Avatar
Default Oil analysis
Like most parts of the country I have been socked in by weather for weeks.
One thing I am planning to do is oil analysis. I had a crack in the turbo oil line and saw a drop in oil pressure to about 20psi for a few minutes. I am curious if there are indications of premature bearing wear.
I am leaning on using Blackstone labs but if anyone has good experience with another lab please let me know.
Charlie Rosenzweig
2021 Dues paid
Old 02-17-2021, 05:36 PM
BillL BillL is offline
If there is a CAT dealer near you they sell sample kits. I have used them for decades. Low cost high quality results. Prepaid mailer and you will get a letter and email. Under $13 each. They do check for coolant, so maybe that aspect has some value too.
No better than Blackstone, just different service, same top quality analysis results.
Bill
RV-7
Lord Kelvin:
I often say that when you can measure what you are speaking about,
is of a meager and unsatisfactory kind.
Old 02-17-2021, 07:41 PM
charosenz's Avatar
Now that is interesting. I was in the dealer last week looking to rent some equipment. It would be interesting to send off two samples one to each lab, and see how they might be different....curious....
Charlie Rosenzweig
2021 Dues paid
Old 03-05-2021, 04:52 PM
charosenz's Avatar
Default Oil analysis looks good
I got my oil analysis report back from Blackstone laboratories. They noted an unusual amount of lead given an unleaded fuel engine, but of course I had to use mostly 100LL on the flight across country. Otherwise they gave it a clean bill of health.
I have not flown recently due to non aviation obligations but the weather has been good and I really hope to get in the air soon.
I did install an headsetinc ANR kit in my basic Flightcom 4dx and while I have not flown with them yet, I do hear a noticeable reduction in background noise,
An unexpected "plus" is that the music sound considerably better with the ANR turned on.
Charlie
Charlie Rosenzweig
2021 Dues paid
