Old 01-12-2021, 09:07 PM
Anon455 Anon455 is offline
Default Don't Drink Alodine
Just a reminder about Alodine and contact with your skin.
I've worked with Alodine for many years, but never had a problem / exposure until yesterday------
Last night, I removed my gloves after alodining some empennage parts (which took about 30 minutes in total). I noticed I had a pin hole in my right glove when I saw the tip of my thumb had turned yellow (like when you've pealed a nice fresh and tasty minneola tangerine).
About 6-7 hours later I felt sick to my stomach and had fever/chills.
Since I never had a problem before and I was at home and there was low risk, I used some cheap latex gloves. I'm sure safety wire nicked them somewhere. Anyway, I've gone back to military chem suit gloves. Maybe overkill, but they're made of Viton Rubber (it says so on the cuff) which has excellent chemical resistance anything I've encountered in aviation. New (Old Stock) they're $2-$5 a pair at just about any Army Surplus store. (Gloves made of Viton from a civilian supplier can be very expensive).
Anyway - just a reminder - especially for you young guys who want a family. And yes I know alodine sucks for the environment and there are new products you can put some ice in and an umbrella on the edge and drink while sitting next to a pool. I encourage you to use them. However, I'm old and should already be dead so I'll stay with what I've got.
Anyway, this morning I looked up the MSDS from Bondrite and was a little shocked to read the "if skin contact" procedure.
Old 01-12-2021, 09:32 PM
scsmith scsmith is offline
Yes, it contains hexavalent chromium, which is really toxic and causes a whole laundry list of maladies in humans and many other living things. It is the stuff that got into the ground water in Hinkley, CA that made Erin Brockovich famous.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 635
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 01-12-2021, 10:36 PM
fl-mike's Avatar
fl-mike fl-mike is offline
I use gauntlet length Nitrile heavy duty gloves for chromic acid (Alodine) and phosphoric acid (etch). Butyl rubber gloves for lacquer thinner. Also a Nitrile apron. Nasty stuff, but all the good stuff is.
https://www.uline.com/Product/Produc...number=S-19714
I donít plan to use Alodine on the next project.
Mike W
Venice, FL
N164WM
Old 01-12-2021, 11:56 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Alodine
When I started on my project I tried to get some alodine here and found out it is essentially banned for private use. I was of course wondering why these crazy Europeans didn't allow such a common substance widely used across all of America, and after a bit of investigation, it became pretty clear this was not the kind of thing you want in the lake where your kids swim.
I used prekote under akzo primer, and it seems to be sticking.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-13-2021, 01:17 AM
JoopSJ's Avatar
JoopSJ JoopSJ is offline
Hello Mickey,
Where can we get PreKote in Europe?
Here in NL they sell Pre-Kote wich doesnt seem to be the real thing.
Empennage, Wings, Fuse .. Done
Working on Finishing and FWF
Donation 2017. . . 2020
Chairman NVAV (EAA chapter 664 - Dutch experimental aircrafts builders)
Member EAA
Member AOPA
Old 01-13-2021, 02:23 AM
rv8ch's Avatar
Default PreKote
I bought it from these guys, but it's been almost 20 years, so not sure.
http://pantheonchemical.com/prekote-...-pretreatment/
I still have some left over, but no idea if it's still good.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Closed Thread
