Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 10-20-2016, 07:33 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Default Possible AD for certain NAVWORX ADS-B Units
Shamelessly plagiarized from another forum: "It looks like there is an AD coming on the Navworx ADS600-B -012, -013 and the EXP 8013 ADS-B Transcievers. The proposed AD is located here. If you are impacted, you have 60 days to comment."
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 10-20-2016, 09:53 PM
scsmith scsmith is offline
Default Hmmmm.
Hmmmm. This isn't great news. Perhaps the Navworx folks can provide some back story? I'm really hoping to buy two of the -EXP units next year.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 635
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 10-20-2016, 11:39 PM
Paul 5r4 Paul 5r4 is offline
Default I'm impacted
The Navworx 600EXP has been installed in my plane about three months. I'm already spoiled and don't want to think about flying without this traffic and weather. Is this just a software issue, something they can rewrite? It looks like this AD will effect about 800 of their ADSB units. Hoping Navworx will chime in today!
Edited: I went to Navworx site and there is information there regarding UPN or unapproved parts notification... what ever that means... and at the end it states to write to the FAA administrator or your congressman.
I'm upset!
Paul Gray
Foley, Alabama
N729PG..... 450+ hrs
RV 7A, Lycoming 0 320 D1A, Sensenich FP propeller
pilotforfun2001@yahoo.com
VAF supporter $$$
Old 10-21-2016, 06:05 AM
Jesse's Avatar
Jesse Jesse is offline
It sounds like the FAA's beef is about the GPS accuracy (which they issued a certification to). For those who have a certified WAAS position source, I would presume that this would "fix" the issue, but I haven't heard this mentioned anywhere.
Jesse Saint
Old 10-21-2016, 06:11 AM
tthrew tthrew is offline
Default aopa article link
https://www.aopa.org/news-and-media/...pn-for-ads600b
I hope this gets worked out - I was planning on buying one of these next year.
Tim
RV-7A N54LH O360 CS 1200+ Hobbs
Joined VAF 2015
2020 VAF dues Paid
Old 10-21-2016, 10:31 AM
Tracer 10 Tracer 10 is offline
Unhappy NavWorx Proposed AD
You have to wonder if the Big Guns producing Expensive ADSB products are working behind the scene to Torpedo NavWorx.
Old 10-21-2016, 10:43 AM
donaziza's Avatar
donaziza donaziza is offline
I hope it gets solved too. I've got a 600 Exp still sitting in th? box waiting to be installed in January. I don't Know exactly which mod?l, I just Know it 's a 600 Exp.
Old 10-21-2016, 11:08 AM
recapen recapen is offline
I've contacted NavWorx - no answer on what they plan to do for their customers - I asked a bunch of pointed questions.
They did request that I comment on the AD - which I did.
Recommend all y'all do the same!
Ralph E. Capen
RV6AQB N822AR @ N06
"Patience"
Old 10-21-2016, 02:52 PM
maus92 maus92 is offline
I'm upset!
You should be upset. As described, this seems to be both a hardware and software issue. Its internal GPS hardware does not and can not meet the specs of the TSO C-154c. NavWorks' older operating software makes it appear to the FAA's system that their device is using a conforming GPS position source, which it is apparently not. The software was changed report the GPS position source's integrity accurately, which in turn makes it non-compliant. Uh, oh....
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 10-21-2016, 03:26 PM
kevin O kevin O is offline
Pls refer to the AD language as well as Navworx notice just posted on their website. This does affect the ads600 exp as well as the certified versions. Not sure that 800 users writing the Faa or congressman telling them our units are accurate is going to change this. I would like to see something from Navworx with solutions should this ruling come to pass. Does anyone know what units are out there that are not affected. Can those components be used in the affected units? Can a 430w, 530w etc be used as position source? If so is a modification of the affected units necessary or just running new wires. Would be nice if Navworx was addressing some of this.
