Old 12-01-2020, 04:39 PM
Avanza Avanza is offline
Smile FUEL FILTER
This is a new installation ?
I should check the fuel filter.
Good Luck
Old 12-05-2020, 06:37 PM
dmattmul dmattmul is offline
Default Sender error
The flow GPM checked ok (38 GPH) I so it wasnít the filters or possibly a check valve issue. The culprit is the sender. Mechanical gauge installed fuel pressure goes up slightly as suppose to with higher manifold pressure. The sender is mounted to the fire wall through the tri-manifold setup Vans uses on the 14. Iíll see if I can better isolate this in case vibration is the issue. If not need to learn to live with 32 psi indicated on departures.
RV-14A QB builds, Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 300-72, Earth-X batteries, Parts became a real airplane 8/15/2020.
Started RV-10 Nov 2020. Empennage arrived (Built) Working on QB kits. Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 3 blade, Earth-X batteries, real airplane hopefully early 2024. Paid subscriber and more. (Worth every dollar contributed).
Old 12-06-2020, 03:14 PM
Dwight----IF the sender is grounded by the body, an over abundance of thread sealer 'might' be giving an intermittent ground. Just a theory---had it happen once years ago in a different application.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 06-05-2022, 07:51 AM
Default Answer
Noticed I never did post the resolution or at least not on this thread. The issue was self-inflicted and want to thank Robert, Steve and all the great RV suppliers out there for the help. Turns out that I had a very slight leak on the input side of the pump in the tunnel. It never leaked fuel, (When I was in the airframe), did not smell because the system is not at any pressure on this side of the pump. (There was a very slight blue stain under the fitting) This small leak must have occurred after each shutdown when I was not in the airframe. The leak allowed air bubbles to enter the system and vibrated the fuel pressure regulator seat damaging it. Last 100 hours system has worked great. Last conditional looked over the tunnel very closely. (Should have installed access panels to make this inspection easier but with pre and post fuel filters located there probably disassembly is the better alternative.
Old 06-05-2022, 08:02 AM
airguy's Avatar
airguy airguy is offline
I had a similar issue on my SDS, I had changed out all my rubber components on the fuel system for running 93E10, but I missed ONE seal on a fuel prefilter, upstream of the pumps, on the left tank. The O-ring deteriorated from the E10 fuel, cracked, and started sucking air. Hard to find... I ended up draining the tanks and pressurizing with air, and spraying soap water all over every fitting before finding it.
It's the little things....
Garden City, TX VAF 2022 dues paid
N16GN flying 1,000 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Pending Repeat Offender - 10 kit is on order. TDI? Turbine? Stay tuned!
