Keep VAF
Going
05-01-2022, 11:49 AM
How to use Quick change yoke pins in Pneumatic Squeezer
Just getting started here and can't find any documentation on how to use the quick change yolk pins for my Pneumatic Squeezer.
I've got most of this Cleaveland kit:
https://www.cleavelandtool.com/colle...c-squeezer-kit
The quick change pins don't seem to fit into the squeezer or yolk as I'd expect them to. Do you remove the rubber washers to install? Do you use a vise / hammer to force them in?
And how do you all get them out -- percussive force with a hammer?
05-01-2022, 12:20 PM
If a new squeezer the pins can be tight. I tap with a hammer to get them to release. Just the metal pins should be removed.
05-01-2022, 12:25 PM
I always put a little grease on the rubber o-rings. Without that, the rubber will get pretty chewed up when inserting and removing the pins. To take the pins out, I push them out with a screw driver or punch.
Brandon
RV-9A: Wings
05-01-2022, 12:57 PM
Same, a little grease and a tap with a rubber mallet, pin punch to remove. After a number of changes, the rubber cuts a little and is easier.
Brian
RV-14A
Build Started 12/31/21-
Section 6 complete 1/30/22
Section 7 complete 3/27/22
*Emp Ordered 9/27/21- Assigned to crate June 2022
*QB Fuselage Ordered 11/3/21- Est 1Q23
*QB Wings Ordered 2/18/22- Est 2Q23
*YIO-390-EXP119 Engine Ordered 5/14/22- Est 2Q24
https://eaabuilderslog.org/?s=RV14A2021
PA-28-236 N419SB
KIWS
VAF donation 2021/22
CAF Member
EAA Member
AOPA Member
05-01-2022, 04:59 PM
Quick change pins
As above…. They will loosen up with time and become easy to slide in and out. I have had a yoke whose holes were slightly off. If you have one yoke that’s really difficult, and others are not, you may need to swap that yoke out.
RV-14A 140658 in progress
Zenith CH801 & 2500A amphibs - flying
Dues 2022 ✅
05-01-2022, 07:59 PM
Oh you're all right -- little grease and I was able to get them in easily. Was briefly thrown for quite a loop there!
05-02-2022, 07:09 AM
I bought quick release pins like these at the hardware store:
https://www.grainger.com/product/GRA...APDP_undefined
I don’t remember the diameter and length, but they are the right size. Smaller diameter for my Tatco hand squeezer, and larger diameter for my pneumatic squeezer. I’ll put a little oil or grease on them once in a while to make it easier, but the pins come out with just a tug and no tools.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2022
05-02-2022, 08:41 AM
Pins
That's what mine look like. No rubber on mine. I did add two neodymium magnets to the body to keep the rings from flopping around.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
05-22-2022, 12:06 PM
Mine were very tight, too, but after a few removals, I was able to push them with my finger. Then I use my cleco pliers to pull them out.
Ivan Dubrov #75069
Building an RV-7
San Antonio, TX (near 1T8)
My build log
05-27-2022, 07:20 AM
Pneumatic Squeezer
I'm thinking about purchasing a pneumatic squeezer also and a thought occurred to me. Would it be better to purchase it with a Longeron yoke instead of the standard 3"?
Thread Tools |
Display Modes |
