Will you be there so we can thank you for engaging our little community of just under 10K airplanes?
That is true. I did forget about that. However, radar does not need xpndr. Tis-b should show up. Also, the ADS-B directive specifically states the ability to turn off outbound ADS-B is not required. Cant see notams overiding that.
As far as I can tell, primary targets (no xponder or xponder off/stby) do not show up on TIS-B. In the case of those of us with 1090ES as our "OUT", when we comply with the NOTAM, we are just a primary target at that point.
Both are supposed to feed the ground transmitters.
"Primary" and "Secondary" targets.....
There has been much discussion around this subject and I am not sure anyone has found a solid answer to the question...
Do you know of any official documentation that details this?
Jim do you have any official word on this?
