Bucking bar access
BonitaRV8
Active Member
Ok, on the forward fuselage skins top row of rivets, what kind of bucking bar do you use to get to the rivets inside of the landing gear boxes? I don't have anything small enough to get in there...
Scott
I used a small tungsten bar, something like 5/8 x 1 x 3", it is a challenge but can be done.
Bird
I recognize it's heresy, but I used a number of pull rivets in spots that were just crazy silly to buck... I figured it was better to do that than to have a bunch of drill outs...
If you can find a pointed/or tapered bucking bar to fit in there, you can turn the pressure up a bit on the gun because the thick material in this area is so robust - it doesn't easily deform.
Emailed Van's and got the OK to use Cherry Max there. I thought, why kill yourself and increase your chances of pounding a bad rivet. Did the same for a couple more that are right behind the roll bar bracket bolts.
