Old 12-27-2011, 08:53 PM
vmirv8bldr's Avatar
vmirv8bldr vmirv8bldr is offline
Default Wire end for AFP Purge arm
What are folks using to terminate the bowden cale that operates the purge valve actuator? The cable ends sold by Vans and ACS has a usable shank of about .025" which is fine if it's actuating a thin sheet of Al, but that control arm is itself 0.25" leaving no room to get a washer and castle nut on it.
Pictures?
I can make something out of a short piece of angle and a couple of bolts and washers, but just wondering if there was something more elegant.
Thanks.
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
Old 12-27-2011, 09:17 PM
Walt's Avatar
Walt Walt is offline
This is what I recommend and use myself for this very important control!:
http://www.mcfarlaneaviation.com/Pro...CategoryID=236
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1900+ hrs, New Titan IO-370, Bendix Mags
Old 12-27-2011, 10:21 PM
DanH's Avatar
DanH DanH is offline
It's not something for which you want to use a solid wire Bowden cable. Buy a real control cable with a threaded end and a locking knob.
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-27-2011, 11:36 PM
vmirv8bldr's Avatar
Default Life-saver
VAF is a lifesaver. Potentially in the literal sense here. (GULP!)
This makes much more sense.
Ordering it tomorrow.
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
Old 12-31-2011, 09:10 AM
Don at Airflow Don at Airflow is offline
Default Cable ends
We prefer using rod end bearings on all control cables (throttle, mixture, purge valve). It not only gives a almost bullet proof connection but also gives good operation if the cable has some offset to the lever. There are plenty of examples of these connections in the appendix section in your Installation and Service Manual. If you need more examples email me at don@airflowperformance.com, and I can send you more ideas from installations we did at our facility.
Don
