Old 12-20-2020, 06:43 AM
ShortSnorter ShortSnorter is offline
Default ELT Install
Does anyone have a pdf of Section 53 they can share with me?
Ryan
RV-14 In-Progress
Build Site
Old 12-20-2020, 07:25 AM
MED MED is offline
PM sent.
MED
140236
N435MD
Miss March 2020
Old 12-20-2020, 09:12 AM
Thanks Mark!
Ryan
RV-14 In-Progress
Build Site
Old 12-21-2020, 12:06 PM
brian@larsentec.com brian@larsentec.com is offline
Watch out for the Pin connections for the power / RS232 connector. I noticed a difference between the Vans Pin connection in their instructions versus the ACK pin out drawing in there manual. I just got info back from Vans and their plans are wrong. Use the Pin out from the ACK ELT install manual.
Old 01-30-2021, 04:51 PM
h2oskibilly h2oskibilly is offline
Default ELT connection
Has anyone found a better way of connecting the ELT Din pin to the Vans supplied harness other than using the molex pins. If it works I guess it ok, but it just seems there should be a better way of making this connection?
Old 01-30-2021, 05:01 PM
mturnerb mturnerb is offline
I used high density D-Sub female connectors - they fit the pins pretty well and worked better for me than the micro molex ones.
Not recommending you do the same but worked better for me.
Blog post here:
https://en.wikipedia.org/wiki/Oxygen...ociation_curve
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 01-31-2021, 08:10 PM
rjkulesa@gmail.com rjkulesa@gmail.com is offline
Default Think you posted wrong link
Wikipedia?
Rich K.
RV-14A Kit #140477
http://www.rkulesa.com/category/building-a-plane/
Empennage Complete
Wings in progress
