VAF on Twitter:
@VansAirForceNet
Old 04-18-2022, 10:56 PM
jcarne's Avatar
jcarne jcarne is offline
Question Sulfur deposits on exhaust valve?
Soooo... having a borescope is a gift and a curse at the same time.
Would this yellowish-greenish area on the valve be sulfur deposits? It shows up on #3 and 4 but not 1 or 2. Also only shows up inside exhaust passage and not on the face of the valve.
Anyone know if this is an issue? I'm guessing not but I don't know what I don't know. Thanks!
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Old 04-19-2022, 06:11 AM
BH1166 BH1166 is offline
If it is, nothing u could do about it right? Lean always till it hurts… change oil regularly. Fly often. Quit the playing with the scope…:-)
Butch
RV6A Purchased N72TX
Old 04-19-2022, 09:25 AM
larryMar larryMar is offline
Great clarity! What set up are you using?
Old 04-19-2022, 09:49 AM
BillL's Avatar
BillL BillL is offline
#1 - you can not depend on the color rendering of the scope to be accurate. If you want to get a scare look at your throat.
#2 - It is just lead deposits.
#3 - don't get too excited about what you see in the scope until you have some more experience. Keep posting . . .
#4 - the resolution IS really good, is it the new VA-400?
Bill
RV-7
Old 04-19-2022, 10:42 AM
gasman gasman is offline
If you want it to look like new....... Just run Propane....
plus, it's only 4.2 lbs per gallon. But the weight of the tank makes up for it...
VAF #897 Warren Moretti
2022 =VAF= Dues PAID
Old 04-19-2022, 01:19 PM
jcarne's Avatar
Thanks for the replies guys, I'm just trying to learn as much as I can when using the borescope and it seems the only way to really do that is ask people with more experience than myself. Just seemed odd that it appears on the back two cylinders and not the front.
Normally wouldn't scope this cylinder but I'm checking each oil change now to see if my exhaust valve is rotating on #4 or not.
The scope is a VA-400 I purchased about a year ago. Never did look to see if it is their new version or not.
Bingo, that's why I keep posting my pics, just trying to learn
Jereme Carne
PPL
Old 04-19-2022, 07:52 PM
Greg Arehart's Avatar
Very little chance it is sulfur. Sulfur is quite volatile at low temperatures so unless your CHTs are in the 200 degree range any sulfur would go out the stack. Since its an exhaust valve, highly unlikely it would be at temperatures low enough to condense sulfur. My semi-informed position as a geochemist that dealt with sulfur for many years.
Greg Arehart
RV-9B (Big tires) Tipup @KCLM or CYSQ
N 7965A
Old 04-20-2022, 08:04 AM
TAB TAB is offline
Default CHT
Check the CHT on each cylinder at cruse, they should be +/-10 degrees of each other. I balance the CHT by trimming or adding aluminum tape to the inlet baffling at cylinders 1 and 2 (lycoming). Your back cylinders may be hotter than the front two; add tape to the front baffling. The factory RV baffling is very well designed and should only require a 1/8" to 1/4" adjustment across the cylinder to make a 20 to 50 degree difference. It takes a couple of iterations to reach an even temperature across all cylinders. You should notice the valve look the same once you achieve equal CHT, provided all cylinders are the same age.
TAB
Old 04-20-2022, 09:04 AM
von_flyer von_flyer is offline
This will make you feel better...
(not mine)
John von Linsowe
Michigan
RV-7
Cessna 140
Drifter
B1-RD
Old 04-21-2022, 10:16 AM
rongawer rongawer is offline
It appears to be a loaded up valve (carbon and lead combustion byproducts). As others have mentioned, brutally lean the engine on the ground - to the point that it stumbles in ground idle, and then just add a touch of mixture to keep it running. Ground idle is the main culprit in fouling plugs and valves due to the lower temperatures and cylinder combustion pressures.
A couple hours of running at full power should help clear it up, but as long as compressions are good, I wouldn't worry about it. Consider running LOP.
Ron Gawer
- RV10, N762G, Build in progress.
- Several others that are now just great memories for me.
