VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Main > Safety
  #31
Old 08-06-2022, 09:10 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Originally Posted by Untainted123 View Post
Iím sure if we got all the Steve Ingra[ha]mís together, it wouldnít take too long
And yes, I _can_ imagine the stream of cuss words coming from you while putting it back on
Iím sure getting all those washers and what not in there is a pain, especially up in the air on the A model.
Didnít you have moving blankets or cardboard and Saran Wrap around your wings also? Could you just do the same around the rudder/VS? Might be the best idea yet.
Yes, perhaps that could be a good idea, but no, I did not have the moving blankets and saran wrap on my plane. The yellow 14A that I took pictures of did. However, he did not wrap the vertical surfaces. I am sure he wishes he had done so.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 08-06-2022, 09:24 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Originally Posted by PilotjohnS View Post
Unless you have batons on both sides, I think the sock will tend to push the ruder over hard left or right
A sock over the entire rudder/elevator with several pockets on each side to slide in battens should work. The sail on my windsurfer had flat fibre glass stiffeners that worked this way. The whole thing would pack away and be relatively easy to install.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, fuselage almost done, working on canopy.
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 08-07-2022, 08:43 AM
MED MED is offline
This is a great idea, in my humble opinion. Perhaps, the folks who make the prop sock could be convinced to make something like this.
MED
140236
N435MD
Miss March 2020
Old 08-07-2022, 08:51 AM
wirejock's Avatar
wirejock wirejock is offline
Default Sock
Originally Posted by wirejock View Post
How about a big sock? Basically a bag that fits the VS and Rudder. Some bungies to hold it down. VS and Rudder become one unit. Less flopping back and forth.
I was thinking three socks. One over VS/rudder. One each over HS/elevator. Each side zippers to the vertical sock. The HS bottoms are bungeed or zippered. Straps sewn into the fabric end in rings. Rings at the tail are clipped with a carabiner to hold it all together. Could be tied down as well.
My wife is a seamstress. I may have her throw something together. Made from something strong and light like the material for tents. Sheds water and breathes.
Something like this "rip stop" kite material.
Tong Gu 39 inch Kite Flag Tent Material Nylon Fabric Waterproof Ripstop Outdoor Camp Cover (Red, 59 x 78 inch) https://a.co/d/b30Gy32
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 08-07-2022, 12:06 PM
This might be difficult to implement so that it works in the very severe conditions where it's most needed. Wirejock's suggestions would help somewhat. I would not rely on this.
Dave
