VAF on Twitter:
@VansAirForceNet
Old 12-05-2020, 07:42 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Default Lower Cowl Exit - Firewall Bump
First off, thanks to CRABANDY for his original work 5+ years ago.
This past week, I decided to add the firewall bump to my RV-7 (as depicted in builders manual, section 12, page 12-2, figures 12-1 and 12-2.)
I've been gathering test data for over 2 years now, and have a pretty solid data set for a variety of operating conditions, power settings, etc.
With the "bump" installed, there appears to be an increase in TAS of 3 kts. This was measured at 6500MSL, 2500RPM, 24.1" MAP, 9.7GPH - 50°lean of peak, 5°C OAT, 30.20"inHg. TAS was 168kts.
CHT's and OT was a few degrees warmer, but all within limits and nothing really concerning:
No Bump - With Bump
285 287
314 314
290 293
276 279
OT:
185 187
I attribute the increase in airspeed to a reduction in cooling drag due to "shrinking the exit".
Next steps -
Change to stainless steel and extend from 15" to ~18" to cover more of the area above the cowl exit.
Cheers!
ID:	5362  Click image for larger version
ID:	5363  Click image for larger version
ID:	5364  Click image for larger version
ID:	5365  Click image for larger version
Brian Decker
RV-7 (Flying)
Last edited by bjdecker : 12-05-2020 at 07:59 AM. Reason: Reordered CHT values - was 2314, now is 1234.
Old 12-05-2020, 08:06 AM
crabandy crabandy is offline
Nice!
Curious if you noticed a sound/tone change with the bump installed.
RV 7 590 hours and counting
21’ donation done
Old 12-05-2020, 10:40 AM
bjdecker's Avatar
Andy,
I think it's a bit "smoother" -- Unfortunately, I don't have a frequency plot before/after to know for certain.
B
Brian Decker
RV-7 (Flying)
Old 12-05-2020, 10:53 AM
DanH's Avatar
DanH DanH is offline
Due to increased exit velocity.
Now think about getting all those tubes and hoses out of the exit flow.
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-05-2020, 04:20 PM
The OP referenced this post in Crabandy's blog.
Dave
Old 12-06-2020, 09:59 AM
bjdecker's Avatar
Nice Dan -- where did you end up putting the oil cooler exit diffuser?
Brian Decker
RV-7 (Flying)
Old 12-06-2020, 01:32 PM
DanH's Avatar
In that early construction photo, it is not cut in yet.
First duct was 4" sceet with glass transitions. Later I built a glass duct with a little larger exit. Been flying it a long time now.
ID:	5403  Click image for larger version
Name:	OC Foam 1.JPG
ID:	5404  Click image for larger version
Name:	10611 and Ductwork.jpg
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-03-2021, 02:55 PM
bjdecker's Avatar
Default The BUMP...
Since I had the cowling off to do surgery on the alternator, I took the opportunity to upgrade the cowl exit ramp/bump from the aluminum version to stainless steel.
I made it a bit wider, taller and included some adel clamps (WDG21019-DG12's) to attach to the engine mount.
Thanks again crabandy, DanH for your work here...
ID:	16620  Click image for larger version
ID:	16621  Click image for larger version
Brian Decker
RV-7 (Flying)
Old 10-03-2021, 07:27 PM
scsmith scsmith is offline
Making it wider is good. You would like to span the full width of the cowl exit opening.
Making it 'longer' is not really necessary. You can accelerate flow happily around a fairly tight radius. Extra length adds more surface skin friction drag without really doing anything beneficial.
The reverse bend that you now have to facilitate mounting with the Adel clamps is not so good. The goal is to create a smooth ramp for acceleration, like a trumpet bell. If anything, you would like to roll a small lip on the edge that goes back the other way. Can you cut the portion out in between the mounting points, or notch it just inboard of the mounting points and roll that middle portion back? In doing so, you may lose some strength, so you might want to put some doublers locally at the mounting points.
Your speed increase is gratifying. You have increased the effective exit area by getting good high-velocity flow across the whole cross section of the exit (assuming the bump spans across the whole exit). You have eliminated the vena contracta in the exit flow that is caused by flow around the sharp corner at the bottom of the firewall. I am surprised you saw slight increases in CHT, since if anything, you have more cooling flow. Perhaps just variation from slightly different run time or other test condition.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 725
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2021
Old 10-03-2021, 08:15 PM
There is a picture partway down the first page of Vetterman's website showing an alternative method of securing the exhaust pipes from side to side movement. The alternate method gets the horizontal rubber hose out of the airflow path near the cowl exit. Here's a link to the page:
http://www.vettermanexhaust.com/
It might be possible to combine the alternate exhaust mount and a firewall bump with a little metal creativity. Might be worth another knot or two and a little better cooling.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019? (actually 2022) RV-10 N46BX
