Keep VAF
Going
01-14-2020, 10:00 AM
Based on the above, does anyone see a need for a sniffle valve on an EFI engine? I would expect fuel leakage to be minimal on shutdown, especially if it's done by killing the pump or ECU power.
RV-7ER - canopy and wiring
01-14-2020, 10:35 AM
The risk of water ingestion remains with a horizontal induction and any fuel system choice.
As for EFI, I have seen a bent connecting rod taken from a GM 6.0L, attributed to hydraulic lock after a defective injector dumped into the cylinder. Do the currently available EFIs hold line pressure after shutdown?
Dan Horton
RV-8 SS
Barrett IO-390
01-14-2020, 04:50 PM
Super Moderator
I was short on my earlier reply on this thread as I was really busy with something. Sorry.
I don?t mean to sound blunt but I don?t understand risking the engine and perhaps the airplane for a $100 part. We install these valves on about half of the non-builder owner airplanes that come through our shop, because they don?t have one installed. A lot of gunk and nasty stuff tends to come out of the intake when the drain plug is pulled to install the sniffle valve.
Where does it all come from you ask? Well it is a combination of a lot of things. First, any rainwater that gets into the intake when it is parked will run down the intake and carry some dirt and debris with it. And that water will sit there and pool if the rain is heavy enough, and may not evaporate prior to you trying to start the engine. Meaning there is the potential for a nice big slug of water to get sucked up and potentially cause a hydraulic lock. Want to understand the potential damage of a hydraulic lock? Read my story in KP this past summer on losing the engine in my stearman which was most likely due to a past hydraulic lock. The damage may not manifest itself for a while.
Second, Fuel drains into the cylinders from the injection system after shutdown, which over time just dries up and cakes with the rest of the dirt.
Third, sometimes there is oil leakage past the intake valves into the intake tubes, which just adds to the mess.
Lastly, on a flooded engine start, the fuel pools in the intake. Run the battery down while cranking and the potential for a backfire into the intake is a very distinct possibility. I have seen more than one crinkled filter on RV?S due to this scenario. I have also seen the damage done to the intake system from a backfire.
Not trying to preach. Just trying to share from experience. I know there are some of you who say their airplane has been running for such and such hours and has no problem. Great. I am trying to share the experience from looking at over one thousand RV?s now and hope it helps you with your decision making. 😀
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES/RW
Kitplanes "Unairworthy" "Diagnostics" monthly feature
EAA Sport Aviation "Checkpoints" monthly column
Author "Pre-Buy Guide for Amateur-Built Aircraft" & "Are your Nuts Tight?"
www.Baselegaviation.com
01-14-2020, 05:45 PM
Originally Posted by DanH
... Do the currently available EFIs hold line pressure after shutdown?
Mine does. Not the full 45 -50 working pressure, but it will hold 15+ PSI for several days.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
1940 Taylorcraft BL-65
1984 L39C - SOLD
RV-8 - SDS CPI - SOLD
01-15-2020, 04:05 AM
Vic,
If all this collected mess can gather in the sump why is the intake of the sniffle valve only 1/16 inch in diameter? It seems it would get clogged up very easily.
(BTW, I have not had any issues over 14 years and 2200+ hours without a sniffle valve but my experience does not necessarily indicate that there is no need for one. I do have a purge valve and a water drain hole and that may account for my positive experience. At any rate, I have now installed a sniffle valve and even at $120 consider it cheep insurance.)
01-15-2020, 04:47 AM
Super Moderator
Originally Posted by ronschreck
Vic,
Most of it drains right after shutdown. Those with sniffle valves will usually see a drop or a puddle at the exit after shutdown.
Consider this?? the plans for the FAB box which is used in vertical draft intake systems call for drain holes for the very same reasons I mentioned in my post last night. Why would we NOT have drain holes in the intake of the horizontal intake systems????
Vic
 Vic Syracuse
01-15-2020, 07:32 AM
Tell us about the exit. Intake water is one thing, but I assume you don't approve of dumping priming fuel into the lower cowl.
Sometimes a sniffle drain can be tricky. Here's an example, circa 2012, my own airplane.
That's an AFP sniffle coupled to a steel line. Why steel? Because the identical aluminum line broke in not very many hours. Why aluminum? Because I went through several flex lines, all of which would not withstand the radiant heat from the 4-into-1 exhaust. Got hard and cracked, melted, whatever.
The kicker? Despite fixation of the aft end of the line, engine shake vs the mass of the steel line broke the aluminum sniffle at the cross pin hole. That's when I thought about it and decided to experiment with no sniffle at all.
I did consider making a sniffle valve using a right angle AN fitting as the basis. I think Mooney used a right angle sniffle. They are just a little ball and a retainer pin. Might still do it, as it would allow running a line directly aft. Maybe Don Rivera would add it to his parts list.
Consider this—— the plans for the FAB box which is used in vertical draft intake systems call for drain holes for the very same reasons I mentioned in my post last night. Why would we NOT have drain holes in the intake of the horizontal intake systems????Vic
I think most of the horizontal induction guys do have drain holes in our airbox or snorkel, although a few builders miss it. I do for sure, and designed the airbox with rainwater in mind.
Thread title is "Sniffle Valve Required". The strict answer is no. However, it's not a trivial decision, and we agree it is good insurance.
Dan Horton
RV-8 SS
Barrett IO-390
01-16-2020, 08:23 AM
I too would like to hear about the exit. I have a sniffle valve, but have been operating without it because I couldn't see a reasonable way to route the drain overboard. I have the same 4:1 exhaust as shown by Dan.
William Slaughter
Houston, TX
RV-8QB
01-20-2020, 01:24 PM
A word from an expert...
This is an interesting thread and I thought it wouldn't be complete without hearing from Don Rivera who is the owner of Airflow Performance and probably knows more about fuel injection systems than anyone I can think of.
So I asked Don if he would mind adding to the VAF corporate knowledge of the sniffle valve. His reply:
Hi Ron,
If you are running a forward facing sump then a "sniffle valve" (manifold drain) should be standard equipment. You have been operating a FM-200 that was built in 1996 which has a purge valve. Using the purge valve correctly to start and stop the engine would preclude getting excess fuel in the engine during a start or shut down. The emphasis here is using the purge valve correctly. You apparently understand the operation of the FM-200 and the proper use of the purge valve. We find that many customers that have fuel controls with purge valves do not use them as intended, in which case may cause excess fuel to drain down the intake pipes into a horizontal sump. This is where the manifold drain would come into play and drain off the excess fuel overboard. Today we sell mostly units that do not require the purge valve, so people do not have to know that operational aspect. But it's probably a good idea to install a manifold drain on any horizontal sump engine whether it has a purge valve or not.
01-20-2020, 04:03 PM
For what it's worth, my I/O-390 sniffle drops anywhere from nothing to a teaspoon per flight, mostly trending to the minimal. But, it's messy in any case, so my valve hose terminates in a small couple ounce bottle which I dump at oil changes. Keeps the hanger floor cleaner!
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
