Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
02-13-2023, 09:43 AM
Inspection plan for SB-00036?
Have any RV-3's been inspected for this bulletin?
If so, what method did you chose to access the hinge area?
Thanks.
George RV-8
"God does not deduct from one's time on earth that which is spent in the air."
02-14-2023, 08:12 AM
Drill a 3/8" hole in the h-stab fearing and end rib, then drop my vividia boroscope. I'll tape over the hole so it can be inspected annually.
Bruce Meacham
Own RV-3 863WL
Built/Own RV-4 254MM
VAF annual donation on autopay
02-14-2023, 08:14 PM
Keeping in mind I don't have a flying RV3 yet, but couldn't the spar be accessed from the inboard end by removing the tailfin fairing and then using a borescope through the inboard rib to view the outboard hinge area.
Chris
02-15-2023, 07:31 AM
Originally Posted by 1rv4
...couldn't the spar be accessed from the inboard end by removing the tailfin fairing and then using a borescope through the inboard rib to view the outboard hinge area.
My horoscope is 2" long and it's a solid rod, it can't bend, so the opposite stab would interfere. I can try it, but I don't think it will work... if anyone has similar ideas, I'm game. A different (flexible/longer/snake-like) boroscope certainly would work.
Bruce Meacham
Own RV-3 863WL
02-15-2023, 07:33 AM
BTW, all the RVs after the 3 use a counterweight elevator and it's super easy to just drill a hole inside the counterweight offset that nobody will ever see. But the 3 is always a little different
Bruce Meacham
Own RV-3 863WL
02-15-2023, 08:33 AM
That is why I hoped to find a 3 owner that had done the inspection.
George RV-8
02-15-2023, 08:39 AM
My outbound fairings are removable, so I took them off and enlarged a hole in the rib. For my neighbors 3 we took off the fairing around the vertical stab and fished the borescope in from the center outboard to get access.
Unfortunately. I found cracks. He did not.
Dave E
Status:
RV-3B, io-320, MT CS Prop. Hot Rod.
02-15-2023, 09:26 AM
There are lots of cheap borescopes (endoscopes) with 6ft. flexible wands forsale on Amazon, under $100. I think one of these would be adequate for what we are trying to do. Has anyone used one with good results?
Chris
02-15-2023, 12:08 PM
I'm not clear on what you mean by "outbound fairings". Can you explain? Thanks.
George RV-8
02-16-2023, 10:58 AM
Inspection
I have a borescope with a 6' flexible wand. I will be out at the hanger this weekend and will be looking at the issue. After I have completed this, I will report back as to how the flex cable works. There is only about 600hrs on my plane, but my father loved aerobatics so we will see what we find.
Taz
Mike Bauer
Technical Counselor
EAA 229 President
RV-3 flying
RV-4 building
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
