claycookiemonster
IO-375 in an RV-8. Not sure if this should be in the -8 Forum or the Engine Forum. As far as I can tell, the Aero Sport Power IO-375 EXTERNALLY is an IO-360, so the IO-360 Baffle kit for an RV-8 should work, but now I see people using the RV-14 IO-360 Baffle Kit on RV-8's
Can someone 'splain this to me? Also, since it's on the lower part of the engine, I'm assuming the intake configuration (Superior Cold Air Sump in my case) doesn't matter.
