Dwg24A is the F-703B angle 1 pice @ 42 3/16 or 2 pices @ 21 3/32
S Soarandtow Active Member Sep 1, 2015 #1 Dwg24A is the F-703B angle 1 pice @ 42 3/16 or 2 pices @ 21 3/32
Zuldarin Well Known Member Sep 1, 2015 #2 One piece Its actually one piece but the plans only show the right side.
BillL Well Known Member Sep 2, 2015 #3 Soarandtow said: Dwg24A is the F-703B angle 1 pice @ 42 3/16 or 2 pices @ 21 3/32 Click to expand... One piece, absolutely. No question. Just mirror the notches.
S Soarandtow Active Member Sep 2, 2015 #4 Thanks One pice is what I thought. Dose it need to be t6 our will local soft aal work ok
BillL Well Known Member Sep 2, 2015 #5 Soarandtow said: One pice is what I thought. Dose it need to be t6 our will local soft aal work ok Click to expand... Take a piece of that soft stuff and you can crush the angle in your hand. Do use some, but not for this piece. Order some extra angle in various sizes for the project. Check Vans List and pieces by part number are cheaper than cut to specific length.
KRviator Well Known Member Sep 3, 2015 #6 Zuldarin said: Its actually one piece but the plans only show the right side. Click to expand... Guess who missed that little detail and has two F703.5B's... No harm done, and my plane is 0.5grams lighter because it is missing the tiny bit in the middle of the two pieces of angle!
