Old 07-03-2022, 09:02 PM
pv9 pv9 is offline
Default RV-8A fuel smell after landing
Hi folks:
I just “adopted” my recently purchased and RV-8A and did my transition training. It is a wonderful aircraft to fly. Lots of minor squawks but a possibly worriesome one that I wanted to consult the experts on this forum on.
I have a carbureted O-360.
After landing with the fuel boost pump on and mixture rich I get a smell of fuel that goes away. This happens every time on landing:
Donated Feb 2022.
Old 07-04-2022, 08:34 AM
Carl Froehlich's Avatar
Look for the telltale blue stains on the fuel runs aft of the firewall, including wing root. Don’t forget to look at the vent lines as well.
Here a small air leak will show up as a fuel smell after running the boost pump for landing. The RV-8/8A fuel line plumbing is challenging - and a source of hours of “loosing your religion” work.
Carl
Old 07-04-2022, 09:27 AM
pv9 pv9 is offline
Carl
Thank you so much. I will troubleshoot based on this valuable tip!
Donated Feb 2022.
Old 07-04-2022, 10:15 AM
Mikeyb Mikeyb is offline
I had a tank leak develop at the famous aft baffle seam. It was small enough I couldn’t see any evidence of it externally but found it with a borescope. I could smell it in the cockpit after landing for some reason.
Good hunting
Mike
N36MB
SN 83764
IO360-M1B
Hartzell Composite CS
Flying Phase 1
KAJO
Old 07-04-2022, 10:34 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Probably not your case, but the -8 is well known to give a fuel smell with full tanks in the pattern because it burps a little fuel out the tank vents, and this migrates into the under-wing passenger vent. It seems more common with a full right tank than left (probably because that is the side the vent is on).
If you’re sure it only occurs with the pump on, then you might well have a leak somewhere - but since you’re new to the -8, figured you should know of this “characteristic”. I think other models will burp fuel out the vents as well, but they don’t have an under-wing vent to pipe the fuel into the cockpit.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-04-2022, 11:00 AM
Check6's Avatar
Check6 Check6 is offline
Default Value of VAF
Ironflight,
This is one of the many reasons this VAF forum is so valuable! Pearls like this. Funny thing was when I saw the post I thought what the heck, then read it and went oh yeah, just took that "uniqueness" for granted everyone else knows this. Nice to keep sharing the nuisances of each airplane type.
Thanks!
Bobby "Luke" Lucroy
Georgetown, Texas (KGTU) RV-8A
Falcon Flight Formation Team
Old 07-04-2022, 02:04 PM
pv9 pv9 is offline
I found these blue telltale signs by the fuel flow transducer cube.
The area around it was dry but there was an oily residue near the corners. It appears that there is a very small amount of vapor coming from there. Aircraft is grounded until this can be traced and fixed!
Donated Feb 2022.
Old 07-04-2022, 02:24 PM
John Tierney John Tierney is offline
Its hard to tell from the photo, but it looks like there may be Teflon tape on the blue threaded fitting going into the red cube. If that is the case it should be removed and replace with a more appropriate thread sealant (lots of debate on VAF regarding favorite products).
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 07-04-2022, 02:57 PM
pv9 pv9 is offline
It could be teflon tape. If so, serious builder error. I'm going to have to inspect everything at this point.
Donated Feb 2022.
Old 07-04-2022, 05:08 PM
pv9 pv9 is offline
Looks like this was a recent “repair” by an A&P who attempted to fix a faulty fuel PSI reading. He put a mechanical gauge in line with the cube transducer to check the PSI and then re-sealed it with Teflon tape.
Lesson learned. Do your own repairs, trust almost nobody.
Donated Feb 2022.
