Old 06-20-2022, 09:42 AM
ERJDriver ERJDriver is offline
Default Baffling
Question for the people smarter than me. Didnít build my 8A, the lower cowl has no silicon baffling material to seal it to the aluminum baffling material mounted to cylinder 1/2. These cylinders run about 20-30 hotter in the climb. Is this why? Cooling ramps are installed in the top cowl and that baffling is new before I bought her
Itís just the lower cowl lip sitting on top of the aluminum, how much cooling/drag am I giving up?
Old 06-20-2022, 09:58 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Are you talking about the cooling air inlets?
Photos would really help.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-20-2022, 04:46 PM
Yes, the cowl inlets where the lower cowl sits on the baffling attached tot the front of cylinder 1/2.
Not my pic but here is an example of what I donít have
Click image for larger version
Old 06-20-2022, 05:06 PM
blaplante blaplante is offline
Well, ya, that's not going to help!!! A multi square inch leak from the upper (high pressure) to lower cowl. I am surprised you can maintain any decent CHT at all.
RV6A in phase 2 as of April 2016
Donation made Oct 2021
Old 06-20-2022, 09:12 PM
Carlos151's Avatar
Carlos151 Carlos151 is offline
Originally Posted by ERJDriver View Post
Question for the people smarter than me. Didn’t build my 8A, the lower cowl has no silicon baffling material to seal it to the aluminum baffling material mounted to cylinder 1/2. These cylinders run about 20-30 hotter in the climb. Is this why? Cooling ramps are installed in the top cowl and that baffling is new before I bought her
It’s just the lower cowl lip sitting on top of the aluminum, how much cooling/drag am I giving up?
Get yourself a copy of OP40-14 which is the baffle installation instructions and drawings. Should have baffle seal material on that lower cowling that will lay over the bottom ramps. That will definitely reduce your CHT’s on cylinders 1 and 2.
ID:	27285  Click image for larger version
Karl Richcreek
RV-8 N151TK "La Otra Chica"
Flying as of August 14, 2015
RV-15 N302TK "La Proxima Chica"
TN26
Old 06-21-2022, 04:58 AM
Yeah giant PIA getting the lower cowl on and off with how the previous guy has it setup
Old 06-21-2022, 05:22 AM
olyolson's Avatar
olyolson olyolson is offline
Default Baffling
I don’t have any baffling material on my lower -8 cowl. The engine sheet metal baffles fit pretty tightly to the lower cowl with just a minimal gap. It is kind of a pain to get on but I figured out just the right amount of leaning, tongue wrist and stretching and of course a small amount of cussing to get it on. It’s not really that bad now that I know the right technique.
There was a dramatic effect on temps when I installed the upper inlet ramps which were not on the plane when I got it. The engine always had pretty high CHTs with #2 always about 20 degrees hotter. I had to pay attention on climbout but now with the upper inlet ramps installed I have no issues and can climb out on a hot day and not worry about temps, even at lower climb speeds. My CHTs are all normal now within about 5 degrees of each other. I also did a lot of sealing around the engine where I had some significant gaps.
I know a couple RV-8 guys and don’t remember seeing baffling material on their lower cowls.
RV-8, Aerosport IO-360, MT 3 blade, AFS 5500
RV grin every flight
"Sure is nice to have smart friends"
Update from Ukrainian RV-6 owner Alex
http://www.rv8.ch/help-people-in-ukraine/
Old 06-21-2022, 05:55 AM
I have an A so the stupid nose gear is what makes it difficult. I guess I can try and tape them off and a what happens. I also don't have the material behind the spinner on that baffling.
Old 06-21-2022, 06:14 AM
Scott Hersha Scott Hersha is offline
Not having baffle seal material on the baffles behind the spinner can be a huge pressure leak, especially if you have the specified 3/8Ē - 1/2Ē gap between the metal baffle and the top cowl surface.
If you install the seal material on the cowl cooling inlets, youíll need to trim the metal ramps back to give you about 1/4Ē or slightly more clearance from the cowl lip to allow you to get the lower cowl on. The surface of the ramp at the forward end should also be ~1/16Ē lower than the cowl lip to allow the seal to lay flat on the inlet ramp. If you can get that OP plans drawing as others have said it will help.
I just finished my baffle install on my RV6 yesterday so itís fresh in my mind. Iíll try to remember to take a couple pics today, so you can see how I did my seals behind the spinner. Thereís more than one way to skin this cat, but it has worked well for me on my other builds.
SH
RV6/2001 built 2000/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/August 2022 build - Phase 1
Cincinnati, OH/KHAO
JAN2022
Old 06-21-2022, 06:29 AM
Carlos151's Avatar
Hereís a picture of the seals behind the flywheel when I was installing them per the baffle kit instructions. I ended up installing nut plates to make it easy to replace the seal material in the future. The more air leaks you seal, front and back, the better your temperatures will be.
Karl Richcreek
TN26
