Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
08-08-2022, 04:57 PM
Rivets and Weights
Hello everyone, I'm getting close to finishing my empennage on a 8A kit and have a couple of issues that have come up I'm needing feedback on. 1st, the drawing calls for MK319 BS blind rivets for attaching the elevator skin to the trim spar (the 4 holes on the end). After inserting these in the bottom I have come to the conclusion that I don't want these round headed rivets on the top skin where everything is countersunk. Is there an alternative countersunk blind rivet I could use? 2nd, I trimmed my left counterweight before I saw right side only. Is this a problem or is it trash (it's all bolted and riveted in)? Thanks so much for your input.
08-08-2022, 06:05 PM
Mk319bs IS countersunk flat head.
Mike W
Venice, FL
N164WM RV-6A Slider/O-360/FP Sold 4/2022
N184WM (RV-8) Flying. Titan IOX-370/ CS/G3X
N184P reserved (RV-8QB) Empennage kit and QB wings in the shop
08-08-2022, 06:19 PM
From the look of the rivet in question, it appears that you should dimple first.
08-08-2022, 09:01 PM
Rivets and Weights
Great, I identified the rivets from the packing list. A search of A/S didn't even turn up that type so I guess I'll have to call Vans. I did dimple the holes and thought it was strange to drill them out for these rivets, but I checked and rechecked the drawing. Any idea what these might be? Thanks
08-08-2022, 09:06 PM
I think the rivet you have pictured is an MSP-42. Look through the bag you probably have both types in 1 bag.
Dave Weisgerber
RV8 N848DW. Ser#83830 done.
James Cowl
DAR inspection on 7-23-2021
First flight on 7-25-2021
Phase 2 on 9-3-2021
08-08-2022, 09:35 PM
That would make sense. The packing list calls for 14ea, MK-319-BS and I have only 12, where as the list calls for 12ea, MSP-42s (of which I have none). So it looks like I switched them around. So now I have to figure out where I put the wrong MSP-42s.
08-08-2022, 09:39 PM
The manual has a page (which I posted a view) of all pop rivet types, full size.
Mike W
Venice, FL
08-08-2022, 09:55 PM
Pull rivets
That's important. MK-319-BS is a tiny bit bigger in diameter than a #3 rivet (7/64"). MSP-42 is 1/8". That means several holes were drilled 1/8". Let us know.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
08-09-2022, 01:54 AM
As for the counterweight, you’re going to have to add that weight back in some how, and maybe a bit more after paint. If. It was me I would drill out the counterbalance skin on one side and replace the weight.
RV-8
Empennage done
Wings in progress
Fuselage ordered
08-09-2022, 05:31 AM
Well the good news is that I accounted for all of the rivets. There are only 5 misplaced. The four MSP-42s drilled to 1/8 are in the last 4 holes on the bottom side skin to the trim spar. Only one MK319 BS is in the folded tab on the elevator. I found that I had placed them in a different bag so I just switched bags. Do you think I should drill the MK319 out and replace it (easy to do at this point) or leave well enough alone? Is there a rivet I can replace the four MPS-42s with (like the oops rivets)? Lesson learned is to use the chart to ID these pop rivets.
I have electric trim so does that require removing weight from the left side? Not looking forward to drilling out all of those rivets. But, if I need to I'll replace it. Thanks again.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
