Old 01-03-2021, 06:11 PM
Marc Bourget Marc Bourget is offline
Consider displacing the center lift backwards with a yoke with a saddle down to the propeller so that the nose is slightly higher regardless of fuel quantity.
The slight leveling pressure, nose down, won't over stress the engine mount.
FWIW
Old 01-04-2021, 05:32 AM
DeeCee 57's Avatar
DeeCee 57 DeeCee 57 is offline
disclaimer: not a structure Engineer myself...
I had some thought about your problem. There are quite a few aircraft hanging in the hangars around here, and most solutions appear good enough. Good enough? Yes, meaning holding up and easy to install and remove
One problem you didn't mention, but worth consideration, is lateral balance, or rather imbalance... as you know there are 2 types of winch systems in use on your field, 2 and 3 pointers. Yours is a 2 pointer, which means you will have to balance the fuel in your tanks, or use additional weights on the lighter wing, to permit lifting your -14 in a wings level attitude.
I had a look a while ago at the system as used on another hanged Lancair Legacy (YMI), and remember the forward attach points on the engine mount/firewall structure, which I think is the best solution. One threaded tube each side accessible thru a small hole on the top cowling.
Now for the rear attach points... ideally a good distance behind the CG to improve stability.
Solution A (I don't have the -14 plans) would be some bar or threaded tube extending from the rear spar. Problem here could be insufficient lateral clearance of your cable/chain system to the sides of the fuse.
Solution B, is there any way to maybe reinforce and use the foot steps base as anchor? (again, no plans, no Engineer)
Solution C would be to use a sling, positioned on one or several bulkheads, maybe using a kind of sled made outta CFK or aluminum (also in your hangar, the yellow Votec is using something like this) to spread the load.
Click image for larger version
Life's short... Enjoy
DC aka Dan
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 01-04-2021, 10:15 AM
If you use a sling, don't use those handy ubiquitous plastic connections. Use a bit of rope to go from the strap to a marine shackle, something like one of these. You can get them to carry the load and they are reliable.
Name:	Snap Shackle.jpg
Dave
Old 01-04-2021, 10:38 AM
SantosDumont SantosDumont is offline
Originally Posted by andrewtac View Post
Any idea of the cost of these?
I think they're like $10-15k
Old 01-04-2021, 10:58 AM
Swiss14A Swiss14A is offline
Thanks guys,
Dan I call you
Alexandra & Fabian
RV14 HB-YAF, in progress
