Go Back   VAF Forums > Model Specific > RV-14
  #11
Old 11-27-2020, 11:27 AM
johnbright's Avatar
johnbright johnbright is offline
Default Mcmaster part number
Originally Posted by rocketman1988 View Post
I used 1/8 wide by 1/32 thick self adhesive neoprene foam tape. Worked great and is available from mcmaster. I have the part number at the hangar...
rocketman Bob helped me find what he used from McMaster... 93375K601
John Bright, RV-6A, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDS EFI EM-5-F
links
Old 01-08-2021, 09:38 PM
mburch's Avatar
mburch mburch is offline
Originally Posted by johnbright View Post
I drilled the access panel #30 to the top skin initially so it can be traced for the cutout.
Just chiming in to say that I did the same thing: Drilled #30 initially, then drilled everything up to #19 together with all the parts clecoed to the fuselage. Worked great and everything is perfectly aligned. Adds a couple minutes of extra work but no worries about holes not lining up.
More pictures: http://www.rv7blog.com/2021/01/08/av...access-panels/
Matt Burch
RV-7 (last 90%)
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 01-08-2021, 10:04 PM
avatty avatty is online now
I happened to call Vans on this same issue today, and was told that the plans should include and instruction to final drill to no. 19 the holes in the access panel covers before dimpling them. But you still need a few of the larger (black) clecos if you go this route.
Tom
Walnut Creek, CA
RV-14 slow-build - fuselage kit in progress
1949 Cessna 140A - IRAN'd 2017
Dues paid for 2021
