Keep VAF
Going
06-16-2019, 11:25 AM
W and b
Hi Chris
Yes, I put the digital level along the canopy longeron. With tires inflated I got 2.7 degrees nose up and just level with the nose wheel completely deflated.
Greg
06-16-2019, 12:06 PM
Greg,
I think you are ok. My setup is almost identical to yours and I weighed with full fairings. My nose was 396. I weighed twice on two separate days and was very careful to have the plane level. I really think it’s just the thick humid air in Houston adding more weight.
RV14A #140083
Flying! 8/12/19
2020 Donation
06-16-2019, 12:12 PM
Originally Posted by DeltaVee47
Hi Chris
Greg
I rolled my 14-A slightly out of the hanger, using the apron slope to get it exactly level. However, that will put more weight on the nosewheel . . .
BTW, my nosewheel was 388.5 with the wheel pant and gear leg fairing.
MED
140236
N435MD
Miss March 2020
06-16-2019, 12:21 PM
No question our air is very nearly a liquid. But I thought letting the air out of the nose wheel would lightened it up. 😉
I was using car digital scales and I noticed that the total weight noted on screen was not the same as if you added the 3 numbers. About 12 pounds heavier on average so maybe the scales are wonky. My sense is that with a proven aircraft built to standard spec the precise numbers are not that important. Probable heresy for which I expect to be flamed. Ignoring PC is one reason I love experimental aviation more every day.
Cheers
Greg
140366
N557GB
04-01-2020, 11:08 PM
Just weighted my -14 and I thought I would share since there is not many taildraggers wt/bal listed here. The mains weighted in at 600 and 601 and the tail 54 lbs. Totaling 1255 with a cg of 79.6 in. This is unpainted but fully primed. Io390 with Hartzell BA prop, earthx batt, berringer wheels, half raven system, dual g3x, gtn 650, classic aero seats and side panels.
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2020
04-02-2020, 07:19 AM
I also have an flying unpainted 14 with Skyvision on both sides and all the goodies including an Avidyne 540 but to plans in most other respects and weigh L 573, R 579, T 57 = 1,209. CG 79.2. Seats are in but no other interior as yet. Once painted, I will provide the final numbers.
One more data point.
Dennis Callaghan (X26)
- RV14 sn:140193 - first flight 12/19/2019
- 2000+ hours on my RV6! Sold (so sad...)
- donation 12/18/2020 * 2
08-03-2020, 02:59 PM
RV-14 W&B
One more data point:
1) EFII ignition and FI
2) Whirlwind C/S Composite 3 blade prop
3) Dual alternators
4) Dual Earth X batteries
5) Garmin full IFR with dual AHRS
6) Skytek NL starter
7) PH Aviation flap motor
8) Full custom leather interior (Yes probably heavier than most)
N: 373
LW: 462
RW: 467
TW: 1302
CG fine min to max weight in utility classification
RV-14A QB building, Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 300-72, Parts became a real airplane 8/15/2020.
Started RV-10 Nov 2020. Empennage arrived and now waiting (And waiting) for QB kits. Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 3 blade, real airplane hopefully 2022.
08-24-2020, 08:42 AM
Paint weight?
Has anyone weighed their RV-14(A) before and after paint, preferably on the same set of scales, to determine how much weight the paint added?
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Reason: typo fix
08-24-2020, 10:19 AM
My RV-14A went from 1267 to 1292 following addition of paint and Classic Aero side panels. Painted by GLO and weighed on the same scales. I did not weigh the side panels separately - sorta wish I had.
MED
140236
N435MD
Miss March 2020
11-11-2020, 09:28 PM
14 W&B
Weighed my 14A today.
Right main: 440
Left Main: 436
Nosewheel: 411
Total: 1,287
Empty C.G. 80.0
Should I be concerned not having the empty CG within the range of Van's design limits of 82.08 - 88.24? The Aft, Fwd, and first flight CG's are all within limits.
Not sure why the hefty nose? 390,Hartzell, B&C backup alt and oil filter adapter, PC680, Skytec, Berringer, full Garmin, Classic seats & carpet, unpainted...
I did get a nose arm of 42.31 inches where others got around 40. (datum 72 in. fwd of leading edge).
Will recheck the arm lengths tomorrow.
Jim Fisher
Manchester, IA
RV-14A 140411
Started Jan 2018
First flight Dec 9, 2020
2020 Dues Paid
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
