Keep VAF
Going
11-01-2013, 06:51 AM
Super 8. Documenting an engine overhaul with JB Aircraft
8 years and ~2k hours of flying the Super 8 and its time for an engine overhaul. I have never experienced one of these (sold my RV-6A a few hundred hours before it was ready.)
The engine has been very good to me and its only troubles over the years I have induced. I have become very attached to the reliability and performance of this IO-540. I picked up the motor from a shop in Florida back in the days where 540's were cheap. Certified and yellow tagged with accessories for $17,500.  Those days are of course over, thank you Vans RV-10.
First few hundred hours were on 1LSE and one mag, then ~300 hours when the mag died, I went dual LSE.
My typically flight is all in to altitude then LOP 2300RPM to my destination so this engine has spent a vast majority of its time LOP. The other times is flying shows with the team ROP and a also a loafing RPM of 2300. CHT's have been kept below 400 generally unless I get on one of my hard altitude climbs to the FL's and I would generally see low 400's to 410 at worst. I have always felt I have treated the engine with respect. Compressions always in the mid 70s with the occasional mid 60 reading that would come back to mid 70's at the next check. Oil consumption was difficult to measure since I spend much of my time upside down with the neg g's tossing a bit even with the inverted oil. Long flights I would see about 1qt over 6 hours and was consistent over its life.
Reaching its 2k hour point, I felt it was time for an overhaul. The engine was not telling me it needed one. I was. The time is right for me during this off season. I can not afford an engine problem March - November.
Back in January I met Jimmy Brod (JB) in Sebring Fl at a show. JB and his dad have run an engine shop, JB Aircraft Services, there for decades. After just a few minutes of talking with JB, I decided that if I ever rebuilt my motor, this is the guy I want working on it. A quiet, humble, down to earth pair of father & son team. You all know how we are about our engines. I dont let anyone touch it that I don't trust my life with. And up until now, no one has touched it but me. I routinely take 'leap of faith' risks flying night ops over inhospitable terrain, hours over open water, IFR ops with no outs below. It has got to be reliable day in and day out.
So off came the motor with the plan to have JB do the overhaul with mostly ECI parts. I have never gone through this process before. I thought I might document that here and report the findings.
Step one. Take lots of pictures so I can get things back to their respective places on reinstall.
Step 2. Pull the motor. Time to pull single handed was 3 hours start to finished on pallet. I didnt break any records. This includes taking the time to tag everything. Here is the engine hanging from my bi-fold door ready to back up the pickup truck. Engine hoist is not tall enough to get this into my pickup truck.
Then truck it down to my local Yellow freight terminal to shipping to JB.
Kahuna
6A, S8 ,
Gold Hill, NC25
11-01-2013, 07:26 AM
Engine Mount
Next was to assess the engine mount. She has been worked pretty hard over the years. A custom built mount by John Marshall(rest in peace my friend) up in Indianapolis. The mount looked fine, but, you can't see under the paint and powder coating. So I pulled the mount for blasting, magnafluxing, and powdercoating.
Here is a shot of the engine mount with the generic nicks, dings and scrapes from years of maintenance.
I found a local shop to to the blasting, maganaflux, and powder coating for $50. i thought that was a pretty good deal. I also inspected it myself after blasting just to make myself feel good. It was in great shape. A new set of mount bolts and the engine mount is back on with a thumbs up checkout.
Kahuna
6A, S8 ,
Gold Hill, NC25
11-01-2013, 07:36 AM
Exhaust Warped
While pulling off the exhaust, I noticed this warpiage located under the heat muff. Hidden for years. My muffs have never been off and I have had no reason to look under them. Hmmm. Whats that?
A quick call to Larry Vetterman... He has seen this before, although rarely. According to Larry, there are 2 cases where this is seen.
1. A wrapped exhaust, or ceramic coated exhaust. I have neither of these.
2. A muff exit blocked where the heat cant get away, either from a scat tube collapse or FW valve that does not dump overboard. Well I have never had either of those.
Either way, it is what it is. A tap with a punch to check wall thickness in the warpage area and Im satisfied that the warpage does not pose any risk so Im leaving it as is. Amazingly, the rest of the exhaust of completely great. I have never had a crack, support arm break, or anything of that nature in its years of service. Im cleaning it up and putting her back on.
Kahuna
6A, S8 ,
Gold Hill, NC25
11-01-2013, 08:20 AM
Mike
I believe that in the certified world the heat muffs have to be removed at least once a year to check for leaks that could come from an exhaust pipe issue and thus get in the cabin air.
As long as I have flown rockets I remove my heat muff in the spring when it warms up and then put it on again in the fall if I plan on flying in the winter.
Even at altitude there are rare times in the summer when you really need cabin heat, a sweat shirt will usually do the trick. This has the added benefit of using that 2" of cabin heat air for engine cooling. Usually this air is just run through the heat muff and then dumped in the lower cowling; more heat added!
I had an exhaust pipe fail once, just aft of the ball joint and it sure gets your attention. By removing the heat muff in the summer it gives you two times a year to really look at this critical area of the exhaust system.
I have about 800 hours on my 540 and I sure hope that it makes it the full 2000 hours. I love these engines.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
12-18-2013, 02:34 PM
Decided to fix this pipe. Fixing this pipe was not difficult. Im fortunate to have friends and resources on the field here. My star smart guy is Mr. Gary Dehart, retired crew chief Hendrix Motorsports. If he cant do it, it cant be done. We set up a jig on his welding table, cut out the offending piece, & fitted in a new one. The joints are not straight by design. With 321 stainless, you also need very tight butt joints before committing rod to metal. Plus he is a perfectionists. I kept telling him we were not going to the moon here. But there is no convincing him that one day this exhaust might have to see duty on the space station or something. I love hanging out with Gary. I always am humbled and learn from the best. Thanks Gary for sharing your shop today.
During the welding process, a remote pressure argon feeder is installed into the pipe to force out air, and allow for a cleaner weld INSIDE and out.
In the end it looks like a simple straight pipe replacement.
Kahuna
6A, S8 ,
Gold Hill, NC25
12-19-2013, 06:59 AM
Well its not everyone that has a neighbor like Gary Dehart, a Championship winning Crew Chief in the Cup series. I think its great that he was able and willing to help out. Yep---its cool to be able to watch and learn for masters like him!!!!!
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
12-19-2013, 08:05 AM
Decided to fix this pipe. Fixing this pipe was not difficult. Im fortunate to have friends and resources on the field here. My star smart guy is Mr. Gary Dehart, retired crew chief Hendrix Motorsports. If he cant do it, it cant be done. We set up a jig on his welding table, cut out the offending piece, & fitted in a new one. The joints are not straight by design. With stainless, you also need very tight butt joints before committing rod to metal. Plus he is a perfectionists. I kept telling him we were not going to the moon here. But there is no convincing him that one day this exhaust might have to see duty on the space station or something. I love hanging out with Gary. I always am humbled and learn from the best. Thanks Gary for sharing your shop today.
His welding hood speaks volumes too. Me likee!!!
Deal Fair
RV-4 (N34CB)
George West, TX (8T6)
11-01-2013, 10:17 AM
Senior Curmudgeon
This is gonna be a great thread-----------thanks Mike
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
11-01-2013, 11:59 AM
Yes it is...any chance JB is going to taking photos of the overhaul?
Ryan Allen, CFI
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 98%, Working on Finishing Kit, AEIO-540 on the stand
Acro Sport 2 on deck.
11-01-2013, 12:08 PM
Inside the valve cover
Why yes he is. Im getting reports in now. The engine has been disassembled. Case sent off. Crank sent off to ECI.
Below is a picture of inside one of the valve covers. JB has mentioned before that he is not a fan of LOP operations and will be very interested in getting inside my motor given all the LOP hours it has.
Kahuna
6A, S8 ,
Gold Hill, NC25
Thread Tools |
Display Modes |
Hybrid Mode
