Old 07-14-2019, 09:25 AM
JackW794 JackW794 is offline
Default Titan O360 Questons
I'm considering putting a Titan O360 into a 6A. I'm concerned about the weight, and weight and balance. I also wonder about using a fixed pitch propeller versus a variable pitch propeller. Any advice?
Old 07-14-2019, 09:41 AM
koupster's Avatar
koupster koupster is offline
I'm very pleased with the CG range of my 6A with an O360A1A and a constant speed. With 80 lbs. in the baggage bin and 400 lbs. in the seats, I can run it completely out of fuel (not that I plan on doing that) and not go beyond the aft CG limit.
Cheers, David
KBTF RV6-A
Old 07-14-2019, 10:37 AM
fl-mike's Avatar
fl-mike fl-mike is offline
IMO, that combo is the sweet spot for a 6A.
That is what I have, O360A1A fixed pitch.
I pretty much cannot get out of CG no matter what I load. Low maintenance on the FP.
A composite two blade CS would be nice some times, but it?s a big cost hit.
Mike W
Venice, FL
N164WM
Old 07-14-2019, 12:45 PM
Default Titan versus Lycoming
Are there any significant differences between Titan and Lycoming O360 engines in an RV6?
Old 07-14-2019, 08:42 PM
fl-mike's Avatar
Carb models are fit equivalent, if that?s what you mean.
Mike W
Venice, FL
N164WM
Old 07-14-2019, 11:13 PM
Default Titan engine
Fit equivalency is very important as are weight and balance concerns. I am wondering if there are any significant issues using a Titan O360 versus using a Lycoming O360.
Old 07-15-2019, 04:04 PM
Jim Ball Jim Ball is offline
Default Titan 360
Stand by for an announcement at Oshkosh for Titan engines specifically configured for VANS aircraft. If you want, email me and I'll send you some specifics sooner.
James Ball (J.B.)
Continental Aerospace Technologies
2039 South Broad St.
Mobile, AL 36695
Phone 251 436 8122
jball@continental.aero
Old 07-15-2019, 06:54 PM
fl-mike's Avatar
No. (Words added!)
Mike W
Venice, FL
N164WM
