Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
11-28-2022, 12:06 AM
With the exception of the whiskey compass which is equally as useless, the fuel gauges in the RV-6 I've been flying for the last 26 years are absolutely a waste of panel real estate. I can put my hand on my heart and say that in all this time I have only once referred to them and that was out of curiosity, to see whether they worked. They do, but only when the fuel quantity drops below 50% do they start to move. Today, I couldn't tell you if they were still working or not. We just never look at them let alone rely on them.
Our practice is to dip the tanks before getting in and then making sure the fuel quantity is reflected correctly on the E.I Inc Fuel Flow Gauge prior to start. The E.I Inc system works great and the rest comes down to fuel management between tanks. I've never been in the habit of relying on fuel guages on any G.A. aircraft. Knowing the engines typical fuel flow and erring on the high side has meant I am yet to run out of fuel.
Touch wood.
Buy a good Fuel Flow system and enjoy the benefits it brings.
Mike
Licensed Aircraft Mechanical Engineer
PPL-A
RV-6, ZK-XTC - Superior IO-360, Sensenich FP, GRT EFIS, Surefly SIM
Bolkow 209-160RV, ZK-MON - IO-320, MT Prop, Retract Nosewheel, Folding Wings
Trustee and Technical Councillor for the MBSAT RV-12 builds in Whitianga
11-28-2022, 01:14 AM
For over 16 years, my Van's fuel gages have been very accurate. I have dedicated ground lines for each gage. I stick my tanks before every flight. The stick is marked per gallon and has been proven to be less than 1/2 of a gallon (5 minutes of flight) off at fill up.
VAF #897 Warren Moretti
2022 =VAF= Dues PAID
11-28-2022, 08:35 AM
Same; gauge wonkiness aside, most of the time my Vans gauges are very accurate.
But, this discussion appears to have set off the gremlins again; when I flew yesterday the left fuel gauge played dead during engine start. Recycling the master switch fixed it. First time my left gauge has done that… looks like one day soon I’ll be dumpster diving behind my panel to swap out both gauges.
John Bixby
RV-8 QB sn 82030 - 1st flight Nov 2006
O-360-A1D/CS prop/Pmags
1975 hrs
Houston, TX
11-28-2022, 09:53 AM
Reason why I will not post my experience over last 16 years with my fuel gages.
Philip
RV-6A - flying 1000+ hours
Donated to VAF yearly since 2007. Why? Because it is worth every penny and more.
There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. —MARK TWAIN
11-28-2022, 09:54 AM
Legal
Is it legal to fly with an in op fuel gauge, asking for a friend?
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2023, worth every penny
RV9A- Status:
98% done, 2% left to go
To Go: wing mounting, engine baffles, wing tips, move to airport
www.pilotjohnsrv9.blogspot.com
11-28-2022, 10:09 AM
Odd for me to say, but my 20 year old Van's mechanical gauges are very accurate, if they read 10 gallons remaining in level flight, and I land and top off they come in +/- 1 gallon. I have a JPI EDM350 and have contemplated moving the fuel levels over to it, but the last thing I want is to go from accurate to inaccurate, so I've decided to leave them as is for now.
Johnny
N455DM - RV-6A - Bought Flying - 2021
Tip Up Canopy
IO-360-A2B
FP 66" Catta 3 blade Carbon
IFR - 2 Garmin G5s - 430W - Aera 760 - GFC500
JPI EMS-350 to monitor the temps
N89WD - Flight Design CTSW - Sold 2021
2022 Donation Happily Made!
11-28-2022, 10:37 AM
VAF Moderator / Line Boy
In an Experimental? Sure - unless the Operating Limits say otherwise. Generally speaking, E-AB aircraft require no instrumentation at all to be legal to fly….
I would, however placard something that doesn’t work as “inoperative”, just because that rule can get fuzzy in the E-AB world with many FAA inspectors….
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
11-28-2022, 11:03 AM
been here awhile
Originally Posted by Ironflight
In an Experimental? Sure - unless the Operating Limits say otherwise. Generally speaking, E-AB aircraft require no instrumentation at al to be legal to fly….
Just for clarification.....the above statement is true for day VFR ops. Most Operating Limitations state night and IFR require compliance with FAR 91.205....pretty sure that is what Ironflight was saying.
Sam Buchanan
RV-6
11-28-2022, 01:41 PM
You may just have a dirty connection. The surge of the master makes a temporary connection.... like a bad starter solenoid on a car that will start after several key movements.
These gauges require clean connections. Clean each one and coat with De-Ox.
11-28-2022, 04:55 PM
I built an early -7A that first flew in ‘03 with vans gauges. 75% of the time one or both of the stock Van’s gauges would die to zero during start and not come back alive. Cycling the master always resurrected them.
Before I got out of phase 1 I put a fuel gauge power switch in the panel. After start I flipped it on and the gauges always came to life and were fairly accurate all of the 15 years I owned the plane.
"The plane won't build itself..." RV-7A N7.62MM sold
-RV4 purchased. Extensive refurbishment complete. “Takes off by it’s self, flys hands off, lands by it’s self...”
-HRII project: paint and panel to go!
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
