ecurington
I mounted my elevators to the horizontal stabilizer last night. With the counter balances clamped in the trail position, the trailing edges of the left and right elevator sides do not align. One side is about ?? higher than the other at the trailing edge. Has anyone had this problem? If so what was the fix?
I read another post that indicated that the elevators may be warped. However, I can not visually tell that there is any warping until I mount the elevators. I do not see how you can warp the elevators unless the pre punched holes are off. My trailing edges are straight.
Eulice Curington
RV-10 Empennage Serial # 40596
Eulice Curington
