RV-14 Taildragger Oil Drain Location
Jetmart
What is the latest consensus the best location on the sump for the oil quick drain on the Lycoming 390 taildraggers?
I put my quick drain (Fumoto T202-N) on the rear of the sump, I believe on the right side. I just chose the side which would give easiest access to attach a drain hose to the fitting without burning my hands. Sorry I do not have a picture.
Left front
I put my SafeAir quick drain at the left front location (see #6 in attached).
Thanks, I have been following that thread. Just wondering if there was a way to avoid lifting the tail for a simple oil change. Less movement means left chance of hangar rash.
Drain
No you do not need to lift the tail. My -14 drain is in the same location as the Vans demonstrator. Rear of the engine. Somewhere here on VAF you can find a picture I posted.
Thanks, I did search for all threads before posting the question. Unfortunately your photo is no longer available. Is yours in the port where there is a standard pipe plug next to the strainer screen?
Here’s a photo of my Fumoto quick drain
This was taken looking up through the lower cowl exit. The quick drain is on the left side, under the fuel pump. The suction screen is on the right.
