  #41
Old 01-25-2022, 08:26 AM
rv7adak rv7adak is offline
Default Reiff heat system
plus 1 for the Reiff works great trouble free from 2006
Old 01-25-2022, 10:33 AM
Prepperpilot's Avatar
Prepperpilot Prepperpilot is offline
Yup. Same thing for me in Ohio. Just plug it in and leave it on. I do open up my oil cap when I leave it on for lengthy time. Put heavy blankets bungee corded around cowl. Keep a my oil at 75F
I know the debate about moisture and corrosion. But I fly often.
New RV-8 Owner - N717SR
Based in Ohio - 9OA5
Former T-38 FAIP
Global Express (Work Airplane)
Slowly getting back into GA Flying!!
Old 01-25-2022, 10:24 PM
rv6n6r's Avatar
rv6n6r rv6n6r is offline
This is a fun thread to watch just for some of the crazy-wonderful innovations!
But I'm seeing some people focusing on oil temps and getting heated up in short times (like, an hour or less). According to Mike Busch on Engines,
All the warm oil in the world won’t help if the crank-to-bearing or piston-to-cylinder clearances go to zero. To avoid this, it’s essential for a preheat to warm up the both crankcase and the cylinder barrels.
That takes time and is probably why Reiff shows warming times in hours not fractions of hours. Just sayin'.
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000, Craftsmanship award AWO 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Last Donated January 2022
Old 01-26-2022, 07:35 AM
wawrzynskivp wawrzynskivp is offline
[i]All the warm oil in the world won’t help if the crank-to-bearing or piston-to-cylinder clearances go to zero. .
Does Mike have numbers for when our engines cold seize?
Seems like the aluminum and copper and babbitt would shrink faster than the steel by their coefficients of expansion/temp
Old 01-26-2022, 07:27 PM
rv6n6r's Avatar
I think the book has those numbers but I don't have it handy at the moment. And he mentions that the numbers won't be the same for every engine since engine wear will be a factor. There's good info in this article at AOPA, but I really think it's worth getting the book, and not just for this. Tons of good info on preheating, cooling, oil, repairs, operation, maintenance etc. especially for people like me who are good with a wrench but not necessarily engine experts.
Randall Henderson
Old 01-27-2022, 02:40 AM
Thanks! I hadn't considered the aluminum bearing webs for the crank.
Old 01-29-2022, 07:08 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
I like #26 blanket. If you look at any real cold weather operators, Northern Canada, Alaska parked outside they put insulated covers over cowl.
Never have done this but some use King Sized electric blanket and wrap the cowl and stuff in the cowl inlets and exit. It may not be fast but it seems to work if allowed to run for several hours or overnight. Is it safe? Up to you to decide. I don't see why not.
Biggest wear factor is long periods of disuse. Flying to full operating temps for 30-60 minutes daily daily makes engine last longer. Short run ups are the worst. If it's above freezing and see oil pressure right after start you are good. Min oil temp before take off? Some say 100F. Lyc states no stumble when applying takeoff power. OP in green of course.
Lyc says
Prehead required when 10F or lower (some 320H models 20F).
Don't over prime (I prime and wait 30 secs or more to crank letting fuel vaporize)
OP indication right after start shortly after normal delay as during warm temps.
Do not low idle (1000 RPM min) to avoid lead fowling of plugs.
When flying OT 165 to 220F
George
Raleigh, NC Area
2021 Dues Paid
Old 01-29-2022, 07:28 AM
MacCool's Avatar
MacCool MacCool is offline
I understand and agree with the value of using a blanket or similar insulated cover if there's a heat source...it makes the heat source, like a Reiff preheater, that much more efficient by limiting convective loss while heating. And I agree that it helps retain engine heat (for a few hours) if applied after shutting down an engine. But after a few hours (depending on the efficiency of that particular blanket) on a cold ramp without any external heat source, the engine will be at ambient air temperature and the blanket accomplishes nothing.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
Old 01-29-2022, 10:24 AM
cderk's Avatar
cderk cderk is offline
I don’t have a DIY engine heater, but I did build my own cell phone switch to turn my heater on as well as a portable space heater to warm the cabin…
Parts list at the end of the video.
https://youtu.be/BVtY0MzXYDs
RV10 N688CD flying since 2020
Lifetime EAA Member
FlyingThe10 on YouTube
FlyingThe10 On Facebook
FlyingThe10 On Instagram
Old 01-30-2022, 06:04 PM
Default Data Points for Reiff
I have two Reiff heater pads adhered to my oil pan.
Overnight temp was 15F. 4 hrs on with cowl plugs in and horse blanket over top of cowl. Prestart oil temp indication was 67F, CHT 52F. Immediately after start oil temp rose to 90F.
Considering where the CHT probes are I think it safe to assume the cylinder barrels were warmer than 52F.
Vincent 'Duck' Wawrzynski
LtCol USMC (Ret)
F-18/F-5/F-16, AH-1/UH-1/CH-53/CH-46, C-130/AN-2
RV-7 complete with all the gadgets
Aviation Safety/Accident Inspector/Investigator
San Jose State University Av Faculty, CFI/GFI S/M (I)
