Keep VAF
Going
01-04-2021, 01:18 PM
Well, that is no fun...
Originally Posted by Mel
If I had an RV-9 and I wanted to do acro, I would certainly put it on a video for my Insurance company to see. It would probably help with my rates to show how good I fly.
01-04-2021, 01:43 PM
Well he's right, though. Doing stupid things is one thing - advertising them is another.
Garden City, TX VAF 2021 dues paid
N16GN flying 750 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440
01-04-2021, 02:29 PM
When I saw the thread title, I started a big batch of popcorn before I even opened the thread.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 635
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
01-04-2021, 03:01 PM
Aircraft capability and safety notwithstanding, I note that my insurance does not cover any flight that exceeds the Operating Limitations on my Airworthiness Certificate. Which excludes aerobatics on my RV-9A.
01-04-2021, 03:46 PM
Spar
Originally Posted by JackZ
The spar is the same on the 7 and 9 except for its length.
This is incorrect. The 9 wing is thicker and the spar is taller then the -7. The -9 fuselage has a different center section than the -7 to accommodate the different wing spar.
Skylor
01-04-2021, 04:54 PM
Broken Links
01-04-2021, 06:21 PM
Too good...
I am now "confused, unsettled and very, very scared." Thanks for the laugh Josh!
2021 Dues paid
RV-6 with training wheel
01-04-2021, 06:57 PM
Skylit
I thought they where the same thickness. I used blocks from a 7to space my centre section during the build and I did not notice any height difference. If the 9 is higher it only reinforces the extra torque math
01-04-2021, 08:16 PM
the spar heights for 7,8, and 9 are the same.
Steve Melton
Cincinnati, OH
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
01-04-2021, 11:23 PM
today was broken clouds in Cincy around 3PM and only 500 ft thick. cruising underneath at 2900 ft and 140 kts I saw a hole and pulled up. I glanced at my rate of climb, 3500 ft/min, and about that time I was above the clouds and climbing rapidly at a nice angle. visions from Top Gun flooded my brain. not aerobatic, but Wow! I ascended to a different world of beauty.
I collected some engine temp data for OAT = 1C with 1 inch wide cowl inlet air dams installed. CHTS were within 10F of each other and my oil temp was 174F. CHT average = 320F at 4.5K ft. EGT as always, 1300F, at this low altitude.
Steve Melton
Cincinnati, OH
Thread Tools |
Display Modes |
