Old 09-01-2019, 10:25 AM
lr172 lr172 is offline
Originally Posted by scard View Post
There is something else going on there. More mass flow isn't what you're looking for here.
+1
especially since this is a new development for the OP. Best to look for what changed and resolve it. Cutting more opening will just create more drag. MANY planes like yours run under 400 in cruise without cutting the cowl, so best to look for other issues causing the overheating condition.
Larry
Old 09-01-2019, 10:50 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Intake flange leak is one possible cause. Also intake tube coupler hoses and clamps can leak.
Pretty common problem.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-02-2019, 03:01 PM
ALagonia ALagonia is offline
Originally Posted by rjcthree View Post
What are your other CHTs, oil temp, are you running
rich, at or lean of peak, carb or injection, what injection, ignition? Engine model? Thx.
Here is the data from two flights.
Sam James plenum
Carburetor
ROP
Flight #1
CHT's at cruise
-375 - 395 - 394 - 411
EGT's at cruise - 1261 - 1327 - 1267 - 1328
6000 feet 72% power 9.0 gph 71 degrees F
14.5 gph at take off power (full throttle)
Flight #2
CHT's at cruise
365 - 384 - 380 - 401
EGT's at cruise - 1259 - 1318 - 1263 - 1330
7,000 feet 70% power 9 gph 67 degrees F
Any thoughts about CHT on #4 cylinder?
Each of these flights lasted right at 2 hours. The numbers above did not change much. On the second flight the #4 CHT did eventually get down to the 390's.
Old 09-02-2019, 05:44 PM
oaklandaviator oaklandaviator is offline
Default Oil cooler
Is the oil cooler mounted on the baffle behind the number four cylinder?
Old 09-02-2019, 05:50 PM
Yes it is.
Old 09-02-2019, 06:13 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
#4 cylinder is leaner than the others. As you have a carburetor I would assume an air leak on the #4 inlet.
Carl
Old 09-03-2019, 01:04 AM
Default Baffle
I would try making a curved aluminum piece to wrap over the number four cylinder and reduce the air lost over the oil cooler. By slowing the air down with a curved blocking plate, you'll increase the pressure available for cylinder cooling and also not adversely affect oil temps because the less air is slowed down and spends more time in the cooler.
Old 09-03-2019, 06:06 AM
jjbardell jjbardell is offline
I added a small air dam in front of my #2 to balance the #2/4 cylinders. Not sure if it?ll help you much since your #2 is also a little warm.
https://photos.app.goo.gl/CVvbLtQsJKH1ruuN8
For my lower cowl mod, here are a few pics. This was very helpful And worth 10-20 degrees.
https://photos.app.goo.gl/jJnxB4WmZxrdQjoN6
https://photos.app.goo.gl/TAgmEaLKyiC5ZGv27
Cheers, Josh
Building - Zenith 750 [11323] CruzerDuty27.5
N67LJ RV9-A [90504] - SOLD
N83LJ Sonex [0864] - SOLD
https://rvpilotlife.wordpress.com/blog/home/
Old 09-03-2019, 07:11 AM
Hard to make out your first two,pics. The last pic showing the exhaust was clearly understandable. I have a Sam James plenum. Any idea how your suggestions would help/affect my CHT?s with my plenum?
Thanks for posting
Old 09-03-2019, 07:33 AM
Thanks for posting
The first pic is looking into the air intake at cylinder #2 (Lyc). The second is the side profile of the cowl cut back 45 degrees to open it up more.
Sorry, no experience with a Sam. They do look sexy though.
Cheers, Josh
