Old 01-14-2021, 08:08 PM
avrojockey's Avatar
avrojockey avrojockey is offline
Default Tracking Down Oil leak - Looking Like a Stud
Pun intended...things were getting too oily so I decided to hunt it down. Here's what I did...
  1. I washed down my O320-E2D really well with Aviation Simple Green and low pressure warm water to get most of oil and grime off.
  2. Finished wiping off any residue really well with avgas and shop paper towels
  3. Inspected engine under UV prior to running to ensure no oil was detected and engine was clean
  4. Ran engine for 5 minutes
  5. Inspected in dark hanger with UV flashlight
I possibly have a drainback tube leaking but I certainly have a cylinder stud or two leaking. Below is a picture of the worst offender. This is only after running for 5 minutes with a normal run-up.
You can see that the oil glows much better than I was expecting. I had read the Aeroshell glows under UV, but the this is Phillips XC without any dye added. In case someone wants to duplicate my process.
Im wondering what the best way to try and seal this up without pulling a jug??? Loctite 290 or low strength 220??? Permatex Spray Sealant
Tim Holmes
Appleton, WI
RV-9A N904DC
2019-2021 Dues Paid
Old 01-14-2021, 09:46 PM
riobison riobison is offline
Good question,
Mine is on the bottom of the cyl thats weeping.
Tim
Old 01-15-2021, 02:50 AM
FLY6 FLY6 is offline
Default UV light
Hi Tim, I too have a leak on my E2D. Had it since I had the engine tore down and upgraded to 160 hp but canít figure out where it is coming from. Is the UV flashlight you are using just a small one or does it have to be one of the larger ones? There are a lot of different ones to choose from.
As far as a cure for your stud leak, have you ensured it is at the correct torque?
Al Grant
Flying RV6, O-320, 160hp
Burlington, On
Dues Paid
Old 01-15-2021, 07:37 AM
664781 664781 is offline
Default UV Light
Buy the 30 or 50 bulb lights on Amazon. Less than $20......
An oil leak will show up as a lime green. Pull your dip stick and shine the light on it to see the color you are looking for.
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 01-15-2021, 08:01 AM
BillL BillL is offline
Default Really?
I heard this and took my UV light and 15W-50 Aeroshell did not illuminate. I wish it had, then I could use it as aero flow tracing fluid.
Maybe it is UV frequency, do we know the range of the specifications that might stimulate oil?
I just got a bottle of dye for the oil. It also works in coolant :-)
Edit: getting no definitive answers for the question, I did a little research on fluorescence resulting in purchase of a 395nm (nanometer) LED flashlight from Amazon. I rechecked my Aeroshell oil for fluorescence and it is indeed activated by this wavelength.
Bill
RV-7
Lord Kelvin:
ďI often say that when you can measure what you are speaking about,
is of a meager and unsatisfactory kind.Ē
Old 01-15-2021, 10:39 AM
avrojockey's Avatar
From Batteries Plus...it's smaller than the picture implies, so it can get into tight places. Worked great!
https://www.batteriesplus.com/productdetails/fla10020
Tim Holmes
Appleton, WI
RV-9A N904DC
2019-2021 Dues Paid
Old 01-15-2021, 07:52 AM
lr172 lr172 is offline
Hard to tell if that is 1 or 2. Is it a through stud or fixed stud? Not a lot of ways to get leaks at the stud, except a bad o-ring or damage bevel but would not expect that at the top. I had a leak from the rod tube seals and it looked just like yours. It was very hard to see the oil between the seal and cyl. Suggest you look more closely there and run your finger over the area where the oil should be and feel for it.
Larry
Old 01-15-2021, 10:48 AM
avrojockey's Avatar
Larry
#2, through stud and it's not coming from anything but the threads so I don't think it the cylinder base o-ring. I understand the through stud leak can only be permanently fixed at overhaul. I'm not nearing that...it just causing a mess. It's not leaking much (my burn rate is 19hr/qt), but as you know even a little gets everywhere.
The engine was so clean before I did the run-up I could eat off it, so if it came from pushrod tube, you would see it above in the picture. I'm going to do check again to make sure
Tim Holmes
Appleton, WI
RV-9A N904DC
2019-2021 Dues Paid
Old 01-15-2021, 11:29 AM
JDA_BTR JDA_BTR is offline
I think a lot of people are going to say at 19 hours per quart be super happy and worry not. Changing oil makes more mess than your leak if it really is one.
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 01-16-2021, 09:39 AM
Through stud is supposed to be a tight slip fit fit with the case bore. Most shops, like Divco, won't let the case out with bolts that do not meet that spec. This type of fit should not allow any significant oil passage. Further, o-rings are used inside the case surrounding these studs to avoid exactly this problem. How many hours on this engine? Loctite on the threads of the nut will do nothing. Would need to remove the jug and put some kind of sealant where the bolts leaves the case, if it is actually coming out via clearance at the stud.
If it truly is coming from the through studs, I would be worried about significant case fretting or a case crack at the webbing. Either way, it needs a professional examination.
