Old 09-08-2021, 10:33 PM
jrock836's Avatar
jrock836 jrock836 is offline
Originally Posted by NinerBikes View Post
I haven't seen any RV-12 Legacy E-LSA builds with timed out motors around or up for sale. The motors can continue to be run "on condition" well past 2000 hrs, if serviced properly and not abused.
These motors are not old school, air cooled, sloppy tolerance, taper bored Lycs or Contis. They keep their tolerances much longer for many more hours run. That and RV-12's don't get used too often doing XC trips, racking up the hours like the bigger RV models.
What I have seen with timed out motors are the S-LSA Legacy RV-12 builds used by flight schools.
Just my opinion, this particular plane is a "unicorn", with an original 2012 build. Back then Skyview D1000's were possible in dash, some were still D-180s, but the HDX wasn't even available back then. Van's had to create a connection box and wiring harnesses for the earliest RV-12s that were wired for Gen1 Dynon equipment so that Gen2 Skyview Classics and Skyview Touches could be plug and play. HDX is Gen 3 and compatible with Gen 2 wiring harnesses, I believe, just plug and play. Not so with Gen 1.
Don't forget TBO is not just based on Hours. Rotax 912uls engines from 2010ish and on will reach TBO (15 years) by age starting in 2025ish..
I definitely won't be taking my loved ones up flying in an airplane with an engine beyond TBO.. I guess it'll be a personal decision each owner will have to make..
Joe
Van's RV-12 #120566 - ELSA - N49DD
Spinks Airport, KFWS, Fort Worth, TEXAS!
DONATED
Old 09-08-2021, 10:36 PM
rvbuilder2002's Avatar
It is unclear to me why are you so often need to pick apart what others are doing. This is an entirely legit airplane that was professionally modified by a professional aviation business. They have their reasons for doing it and have now sold it to a new owner. It is just as much an ELSA RV 12iS, as any other.
Aside from that, a lot of you info presented here is just plain wrong.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 09-08-2021, 10:42 PM
greg gfeller greg gfeller is offline
I saw this airplane in Lockwood's shop in February 2020 when I took the Rotax service course from Dean Vogel (which I might add has been invaluable). During the breaks we could walk around the shop. I recall saying to myself if this is what a detailed condition inspection looks like I must really be slacking. The old engine was still on the plane, prop removed, everything in the cockpit and fuselage was completely opened up, fuel tank removed etc. Now I know why......and maybe I'm not a total slacker. Nice plane!
Old 09-10-2021, 09:45 PM
RFSchaller RFSchaller is offline
Another issue to consider is the insurance. How would they react to a claim on an aircraft that has an engine beyond recommended overhaul time?
