Go Back   VAF Forums > Model Specific > RV-15
  #11
Old 07-27-2021, 02:06 PM
FresnoR's Avatar
FresnoR FresnoR is offline
Default My 2014 Prediction
From the 2014 photoshop fun. Just in case, this can be for my "Rick tells the future" folder
Rick from Seattle
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 07-27-2021, 02:26 PM
mfleming's Avatar
mfleming mfleming is offline
Not bad
That would work for me
A few things to improve:
  • Stouter tailwheel assembly
  • Spring steel gear like the -8
  • Taller gear
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring and Avionics harness completed 9/2/2021
FWF Started 9/3/2021
Donated for 2021 and so should you
Old 07-27-2021, 05:52 PM
bigbill25's Avatar
bigbill25 bigbill25 is offline
I'll put in my guess for a side-by-side with a 915is up front. A turbo would be great for high/hot back country work.
Old 07-27-2021, 06:00 PM
PCHunt PCHunt is offline
That tailwheel needs way more ground clearance!
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2021 Donation+, Gladly Sent
Old 07-27-2021, 06:04 PM
mfleming's Avatar
915is = 141HP
A bit anemic for a bush plane
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Old 07-27-2021, 07:08 PM
N64GH's Avatar
N64GH N64GH is offline
Most likely
Mike Divan
N64GH - RV6,flying
Once an Airman always an Airman (SSgt 78-82)
FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS!
Old 07-27-2021, 09:15 PM
emsvitil's Avatar
emsvitil emsvitil is offline
All Aluminum
180Kts VNE
145Kts cruise
25Kts stall
side by side since there's already lots of tandem bush planes
Ed
Old 07-27-2021, 09:21 PM
Taltruda Taltruda is offline
Originally Posted by mfleming View Post
915is = 141HP
Perhaps at sea level, a Lycoming has more power than 141hp, but at higher elevation airports in the back country, a turbo 915is is still making 141hp, while that same lycoming is way down on power, probably less than 141hp (depending on the altitude)
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 07-27-2021, 09:24 PM
Mike Houston Mike Houston is offline
Default Engine choice and competition
915is = 141HP
Sling are already finalising a high wing version of their 4 seater TSI using this engine capable of 167 mph. Mind you it’s a bit slow off the ground at 700ft. However a 2 seater using this engine and not pull rivets etc could be a decent performer I would think.
Personally I hope they have an engine option which is Fadec controlled and uses Mogas. Either Rotax or ULpower?
Old 07-27-2021, 09:57 PM
NinerBikes NinerBikes is offline
Except for the price of the 915is... and grousing that 135 hp continuous wouldn't be enough?
Also an issue of center of gravity, since the power plant is pretty light. Don't really know how hard on the boost you can run a motor like that, all the time? There would be a lot of plumbing involved for water cooled heads and a large sized oil cooler, for that kind of HP coming out of a 1365 cc little motor.
But it would be premium 91 octane Mogas capable.
Donated
RV-12, KWHP based
"Time to Spare, go by Air."
