Go Back   VAF Forums > Model Specific > RV-15
View Poll Results: Pull Rivets or Solid Rivets?
Pull Rivets 59 33.52%
Solid Rivets 117 66.48%
Voters: 176. You may not vote on this poll
  #11
Old 07-27-2021, 08:02 AM
N8DAV8R N8DAV8R is offline
Originally Posted by mburch View Post
I voted "pull" but what I actually want is more nuanced than a binary choice. I love squeezing rivets and I don't really even mind driving rivets when I can get my hands on both sides to buck them myself. What I really hate is two-person rivet bucking, since the reliability and availability of your riveting partner becomes a challenge. Not to mention, bucking the rivets inside the fuselage and wings usually involves a lot of painful contortions. So I wouldn't mind a combination of squozen and pulled rivets in order to make solo building easier.
This is similar to my thinking. I'm building a -12, just about at the end of the fuselage kit. Contrary to what a lot of people think about us "assemblers" (I see you over the NYTOM ), there is some actual airplane building and lots of solid rivets in the -12. You get plenty good at prepping for and squeezing solid rivets. I just finished getting the roll over structure all drilled out and countersunk, a task that most people will have "assembled" essentially the same way I did regardless of model.
I have enjoyed the build so much that I'm thinking about what to build next more than I think about going flying. The priority for me is a comprehensive design, documentation, and modern precision kit parts. My opinion is that those things will make a build more enjoyable than one type of rivet or another. If the next kit is well thought out, I'll be glad to have a bunch of dimpling and pounding to do. A little noisy, but I think my neighbors already have me pegged as the crazy guy building an airplane in the garage and will leave me alone.
Anyway, yeah. The idea of a solid rivet airplane biased towards squeezable rivets is attractive to me. I guess that's only practical if a bunch on the skins are blind rivets. By the end of the fuselage kit I think I actually prefer putting in squeezed solids to pulled blinds.
Nate - Salida, Ca
RV-12is - Fuselage kit in progress, wings and tail complete
Old 07-27-2021, 08:21 AM
mfleming's Avatar
mfleming mfleming is offline
I’m assuming this poll is related to the new -15.
Insomuch as this design is backcountry capable, strength is the primary concern. Bush or backcountry airplanes take quite a beating, therefore in an ideal world, universal head solid rivets would be used for maximum strength.
Solid universal head rivets would up the build time considerably so maybe a mix of universal, flush and pull rivets could be used were appropriate.
It doesn’t have to be all or nothing.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring and Avionics harness completed 9/2/2021
FWF Started 9/3/2021
Donated for 2021 and so should you
Old 07-27-2021, 08:44 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Don't forget repair - particularly field repairs. Poop happens.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 07-27-2021, 01:28 PM
joeboisselle joeboisselle is offline
How about AN470 rivets instead of 426? I like the aesthetics.
Joe Boisselle
2010 RV-4
1941 Luscombe 8C
Old 07-27-2021, 03:25 PM
Berchmans Berchmans is offline
Default Strenght is king
I live in Alaska and fly a RV8, Cessna 182 and a Citabria 7GCBC on floats. if this going to a true back country aircraft it will get used and abused here in AK. Strength is king. I fully intend to buy this kit and assume it will be a great replacement for the Citabria...a pulled rivet construction method would give me pause.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2021
Old 07-27-2021, 03:40 PM
terrye terrye is offline
Default Poll - Pull or Pound?
I'm building a -9A and vote for solid rivets on the RV-15/16. In the overall scheme of building an aircraft, I don't think the pulled rivets give a noticeable time saving. Pulled rivets, whether dome or countersunk head still have a hole in the middle from the break stem. Potential water leak path, water freeze path, in addition to harder to paint and keep clean. Definitely solid rivets (I'm sure Rian at Vans has already made this choice).
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 07-27-2021, 03:47 PM
wirejock's Avatar
wirejock wirejock is offline
Default Pull or solid
I doubt a poll will change all the engineering Vans has already done. I suspect it's a "Done Deal".
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 07-27-2021, 03:51 PM
mfleming's Avatar
Maybe...but then why take a poll at the presentation
I believe that's what's driving this conversation...some hope that Van's is listening...
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Old 07-27-2021, 04:01 PM
wirejock's Avatar
Default Poll
Doh! Sorry. I didn't see that. Nevermind! My vote is still pounded rivets. However, I do see the value in a quick RV12 type back country bird.
Larry Larson
Estes Park, CO
Disclaimer
Old 07-27-2021, 07:16 PM
JohnD.TF4 JohnD.TF4 is offline
Originally Posted by NYTOM View Post
Probably just me and donít mean to knock the assemblers out there but pulled rivets just look cheap, amateurish and temporary. Obviously they are the required for certain special situations but otherwise just makes the project look like a high school shop project. Take the time and effort to use solid rivets for a more professional build. Sorry but just my stinky opinion.
Considering all of the other skills you master over the course of an building an airplane, learning to buck rivets is trivial.
Pros: Looks better, lighter, cheaper, faster (flush rivets), makes a cool sound when you install them, WAAAY easier to paint. I've masked N-numbers for paint on nearly 30 pop-riveted airplanes. Words cannot accurately convey the royal pain that process is.
Cons: slightly harder to install.
In case you are worried, check out the RV-12 vs RV-14 build times. They are very close despite the rivet differences. In my opinion, the big deal for build-ability is the format of the build instructions and the matched hole punch.
John D
RV-12(ULS and iS) Pilot,
Restoring RV8A,
General Purpose Airplane Nut, etc,.
