Old 03-24-2021, 02:41 PM
jrock836's Avatar
jrock836 jrock836 is offline
Thanks for the input guys.. I can now see there's not a widely used method used by most of you guys.. Guess I will just play around with it and see what I can come up with that does a better job of protecting the paint and hopefully looks decent..
Cheers!
Joe
Van's RV-12 #120566 - ELSA - N49DD
Spinks Airport, KFWS, Fort Worth, TEXAS!
DONATED
Old 03-25-2021, 04:11 AM
I-TERA's Avatar
I-TERA I-TERA is offline
Hi Joe,
I looked for washers that would allow to withstand radial and axial loads without deforming the substrate (fiberglass), but without success. For the axial load the washer must compress the fiberglass and for the radial load the washer must enter the fiberglass with a cylindrical, not conical hole, to avoid deformations and fractures.
Finally I decided to make some special turned washers, and make a tool to prepare the hole in the fairing in correspondence with the fixing hole. The installed washers are glued (epoxy) and painted. So far (4 years) they hold very well and the fairings still adhere without deformation or fractures.
Here the link to the images.
https://www.dropbox.com/sh/49ialxn7q...QGuvddEca?dl=0
Claudio
Claudio Ricci
F1 Rocket EVO
Old 03-25-2021, 04:36 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by jrock836 View Post
My upper cowling has cracks and paint damage, mostly around the Phillips head screws....Has anyone found a better washer/screw combo to use that will protect the paint and distribute the load better than the little plastic washers under the phillips screw head?
Curiouser and curiouser.
I think the question here is why you're getting cracks and paint damage under nylon washers and AN526 screws. It's not the washer and screw choice, which are structurally superior to tinnermans. It more likely goes back to prep and paint choices.
Look at the back side of the panel. Do the cracks extend through the fiberglass? Now look close at the painted side. Are the cracks in the paint only?
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-25-2021, 04:46 AM
thiggins thiggins is offline
Originally Posted by I-TERA View Post
Hi Joe,
Claudio
I canít believe Iím saying this, but those are some beautiful washers. Too bad no one produces them. Really spiffy.
Donation 2020 paid
ASEL INST COMM Tail-wheeler
RV-12iS (Building it's shop right now...)
Old 03-25-2021, 07:24 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Another option...
This may be an option for your cowling. I used these the secure my fuel tanks which were painted separately from the wings as I didn't want to be dealing with painted screws when removing the tanks. (Yes, tank removal is not uncommon!) They are called flush or finishing washers and can be purchased for all the screw sizes we typically use.
[url=https://www.flickr.com/photos//[/url]
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours- Sold
My Aerobatic Video
My Formation Video
CAF B-25 - Airbase Arizona
VAF 2021 Donor
Old 03-25-2021, 09:24 AM
jrock836's Avatar
Hi Joe,
Claudio
Wow, those are beautiful!
Joe
DONATED
Old 03-25-2021, 03:06 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Nickel Plated Flat Washer - Does that have 100 deg countersink to match aviation flat head screw?
Where to buy / PN?
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 717
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 03-25-2021, 06:01 PM
skydiverlv skydiverlv is offline
Wicks Aircraft Supply.
I use these on my spinner
https://www.wicksaircraft.com/shop/6...hoCGbEQAvD_BwE
Larry Vandegrift
ULPower 260is
Old 03-25-2021, 09:04 PM
RFSchaller RFSchaller is offline
The only countersunk screws on my cowling are for the upper cowling attachment pin retainer plate. Everything else uses #8 round head machine screws with flat washers. No cracks after 9 years and just shy of 1100 hours.
Old 03-26-2021, 05:58 PM
BillL BillL is offline
Hey, Ron, I have a box of these washers and never discovered the perfect use for them, but- just this week (first 'annual' since paint) got some paint turn-out with my screws (@#$%^&). Will these stick to the paint and prevent that post paint?
Bill
RV-7
